HELP WITH TIMING BELT! ASAP --- d16
!!!!HELP WITH TIMING BELT! ASAP --- d16
ok i have a strap wrench and high impact tools... i need to get the crank pully BOLT off..... i am impacting it to the LEFT if you are looking straight at the pully. i am doing it under the fenderwheel. i am turning it COUNTER-CLOCKWISE..... am i doing it correctly? because it seems like this bolt is never comming off...
just need to change my timing belt and it is being a pain!
help HT guys!
CAR is a D16
Modified by SpOoLiNg CiViC at 2:43 PM 1/3/2007
help HT guys!
CAR is a D16
Re: !!!!HELP WITH TIMING BELT! ASAP --- d16 (SpOoLiNg CiViC)
If you've never pulled it off before, it's likely it won't come off easily (or in 1 piece).
There's a special tool (forgot the name) that you put around the crank bolt to hold the crank pulley in place. You then either use an impact wrench or a ratchet with a long breaker bar on it to loosen it. People have broken several wrenches and ratchets on this bolt.
As for me, I ordered a new one from the dealer and my neighbor went all out on it. The top of it snapped off and we drilled it out
how i get mine off is.. take the belts off....then use that vice grip with the chain on it i don't know whats its call but it'll hole that pully like a pitbull on a rag dog position the vice grip thing on the axle so when you turn it the axle well stop it form spinning use a extension so it goes pass the fender then use a 5 foot pole and slide it on the 1/2 rachet than put you weight at the end of the pole and it should do the trick
this is where the warranty for the tools come in handy as i went through three rachet
There is a Honda crank pulley tool you can purchase that is very useful..
OR
You can get a phat *** breaker bar (about 3 or 4') with about a 20" extention & 19mm.. put a big flat head screw driver/pry bar at the flywheel and take it off that way.
OR
throw some heat to it and work it back and worth (loosen,tighten,loosen,tighten...etc.) and it should come free also you could try soaking the **** out of in PB blaster or something of that nature either way impact gun is your best bet....i did a timing belt/waterpump on my b16 and i snapped my timing belt (OEM honda one) trying to loosed the crank pulley bolt with a breaker bar.
Re: !!!!HELP WITH TIMING BELT! ASAP --- d16 (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">There is a Honda crank pulley tool you can purchase that is very useful..
OR
You can get a phat *** breaker bar (about 3 or 4') with about a 20" extention & 19mm.. put a big flat head screw driver/pry bar at the flywheel and take it off that way.</TD></TR></TABLE> This is the way i did it the first time, but the tool he is talking about is awsome, for the 25 or 30 dollers you will spend on it you will make up in the amount of time youll waste trying to get that bolt off. Think of it like this you will never be scared to do a timing belt again.
OR
