cometic head gaskets are poop!
Old Aug 30, 2002 | 07:54 AM
under_psi's Avatar
Default cometic head gaskets are poop!
fuggin thing blew after 7000kms
it's an 84.5mm cometic head gasket BTW...only reason why I bought it s because Honda was backordered for the OEM CRV head gasket.
when I first instaled it the fitment was **** as well, I'm not surprised i let go so soon.
from now on, stricktly OEM gaskets!
I'll post pics of the cometic gasket as soon as I pull the head off....
BTW, this head gasket was used on my cr/vtec and is supposedly "designed" for the frankenstien motor it actually looked like a B18C head gasket with bigger bore...evenhad the hole for the internal oil feed in it. Oh well, a lesson well learned.
[Modified by T.O.tegs, 4:55 PM 8/30/2002]
Old Aug 30, 2002 | 08:10 AM
kekek-20's Avatar
New User
Default Re: cometic head gaskets are poop! (T.O.tegs)
are you sure it was something wrong with the headgasket that caused it to blow?
i run a cometic on my b20 and everything is fine.
is your car detonating at all? did you check your plugs?
Old Aug 30, 2002 | 09:41 AM
dohcsideSi's Avatar
Default Re: cometic head gaskets are poop! (kekek-20)
cosmetic gaskets suck i've had too many problems on quads and dirt bikes to even think about using it on my cars....last time i talked to vince @ http://www.goldeneaglemfg.com he said they have oem gaskets punched out for larger bores vtec and non vtec!!
Old Aug 30, 2002 | 11:45 AM
sgT's Avatar
sgT
You probably got the wrong gasket.
I havent had any problems with cometic so far.
and as far as boring out stock gaskets, you really cant do that because the
sealing ring isnt far enough out to support that large of a bore.
Old Aug 30, 2002 | 12:20 PM
Tony the Tiger's Avatar
Camille, did you end up going to the track with the motor untuned? I hope you didn't push the motor because you were detonating above 6500RPM...
Old Aug 30, 2002 | 01:08 PM
under_psi's Avatar
Default Re: cometic head gaskets are poop! (Tony the Tiger)
Tony, I did go to cayuga dragway...just cause I couldn't wait but I backed off the timing LARGE and upped the fuel pressure..didn't seem like I had any more detonation at all...felt like I lost a **** load of power though but still ended up joining the 13 second club my cousins straight B20B hatch is now also a 13 second car ...now I just hope I didn't contaminate the bearings or anything
SGT: the gasket I got said B18B/B20B with vtec head 84.5mm I'm sure it was the right one. I'm never using it again however
Old Aug 30, 2002 | 01:19 PM
non-VTEC's Avatar
damn that sucks man....................i'm using a OEM CRV headgasket...........no problems so far...............that i know of.........
Old Aug 30, 2002 | 06:55 PM
sgT's Avatar
sgT
well, you said yourself it had the oil pressure hole in the gasket so obviously it wasnt
the correct gasket regardless of what the packaging said.
Old Aug 30, 2002 | 07:03 PM
ITR21's Avatar
Default Re: cometic head gaskets are poop! (sgT)
ive had problems in the past with preformance shops sending me the wrong part as well.
Old Aug 30, 2002 | 09:28 PM
TREVER's Avatar
Default Re: cometic head gaskets are poop! (ITR21)
I have installed dozens of Cometic gaskets and have never had a problem.
what was the warpage on your deck and head. do you have a straight edge and some feeler gauges? I would check the basics first.
My buddies 85mm 245 whp na gsr motor uses one no prob.
Cho0se
Feb 24, 2020 02:59 PM
Brycen
Jan 1, 2010 02:20 AM
-Darren-
Jun 2, 2009 03:54 PM
prietito69
Apr 1, 2008 06:27 PM
king tuck
Oct 7, 2004 04:15 PM
