s300 h22 basemap, too rich.
i have a built h22a, when i installed my new s300 hondata, n i try the hondata h22 basemap it will not start as i realised, the injector size from the hondata basemap is 440cc.
the injectors i have at my h22a is 340cc.
so does any1 here at honda tech has a basemap of h22a, 340cc injectors. i would really appreciate it. ps; the country i live in does not have a qualified tuner.
You can use the Stock P72 map for your car with the 340cc injectors. Don't change the injector scaling, if will start up and run on a stock gsr map.
Just tune from there.
i ve tried using the p72 gsr basemap. i still have problem starting the car. There is a red led light coming on. Is there something wrong with my ecu or my wiring??
