sway bar and headlight questions
i have a 94 civic CX hatch what will it take for me to put a rear lower sway bar on? right now i have teg RLCA's
and what is a good way to get my headlights brighter without going projectors or HID? right now i have PIAA bulbs in my with stock headlight assembly
thanks
thanks
really the only other option for brighter headlights if you dont want to go hid is the teg 9005 conversion thing... do a search or ask someone on the teg board how they did it...
and the swaybar... time. ...and the hardware for mounting, if you already got lca's they might work, i have no clue though... I've never messed with swaybars so someone who knows could tell ya i guess... or you could search for that too
rear upper sway bar or lower...the upper is easy remove the plastic pieces in the back for lower u have to remove control arm bolts and then but bar in between there then put the bolts back on
Blue-Civic-Hybrid
Jan 21, 2003 05:13 PM
1fastGSR
Acura TL, RL & ZDX
Mar 17, 2002 02:58 PM
