Acura RDX Fuel Injector: 410cc
Old Oct 22, 2009 | 01:28 PM
tweek_boii's Avatar
Default Acura RDX Fuel Injector: 410cc
Would Acura RDX Fuel Injector: 410cc (39 lb/hr) work with my RBC ???
Old Oct 22, 2009 | 02:05 PM
nahonda04's Avatar
Surje.motorsports
Default Re: Acura RDX Fuel Injector: 410cc
yes they will work but you you will need to get different clips to hold em in
Old Oct 22, 2009 | 08:14 PM
hawaiiancb74's Avatar
u can get the clips from a scion.. and yer gona need engine management,
Old Oct 23, 2009 | 12:34 AM
tweek_boii's Avatar
Any other mod after
intake / intake manifold / header / exhaust
requires K-Pro ..
Old Oct 23, 2009 | 01:34 AM
dc5RickK20's Avatar
you actually need k-pro when you swap for the RBC without it you lose power
Old Oct 23, 2009 | 10:13 AM
tru
Old Oct 24, 2009 | 02:17 AM
tweek_boii's Avatar
I didn't lose power.. Just stayed about the same
Old Oct 24, 2009 | 02:42 PM
its not much of a loss, but when we were working on them in the beginning we lost power just bolting them on.
Old Oct 26, 2009 | 11:20 PM
tweek_boii's Avatar
Are you referring to the injectors or the RBC mani ?
Old Oct 27, 2009 | 05:29 AM
turboteg2nv's Avatar
^^ He was referring to the manifold. You need engine management (Kpro) to scale down the injectors...otherwise you'll just be dumping fuel into the engine and you'll fowl out your spark plugs.
What makes you think you need bigger injectors anyway? What's the current duty cycle of your OEM injectors (I bet you don't know the answer to this question )
Rule of thumb is not to exceed 80% duty cycle on injectors.
Old Oct 27, 2009 | 06:39 AM
02 i-vtec's Avatar
actually u can use the oem clips..
Old Oct 27, 2009 | 06:40 AM
02 i-vtec's Avatar
all you have to do is flip the clip and get a dremel and dremel them down so they fit on correctly.... but u have to flip the clip backwards...twist it in other words.. if you have any questions pm me..
Old Oct 27, 2009 | 10:44 AM
Don't enable homeboy when he hasn't done his research
Old Oct 27, 2009 | 03:42 PM
i know the rdx inj have a great atomization pattern, can net a few hp
f4it
Feb 11, 2008 12:32 PM
green eyed bandit
Jul 22, 2007 10:41 PM
rwasmund
Feb 23, 2007 02:59 AM
SFlCrx
17
Oct 28, 2006 09:49 AM
Teluan
Sep 4, 2001 09:49 PM
