Rear upper ball joints?
Old Oct 21, 2009 | 06:00 PM
SKDRCR's Avatar
Icon6 Rear upper ball joints?
Sup fellas
Has anybody been able to find rear upper ball joints w/o
replacing the entire control arm?
I've replaced the front uppers which they sell separate from the control arm
and also have a 1 degree camber adjustment. They almost look like the same
diameter as the rear upper bj's so I'm wondering if I can just use some more
front ones on the rear control arm. Has anyone tried this?
Thanks for the input yall
Old Oct 21, 2009 | 09:38 PM
gstrudler's Avatar
Default Re: Rear upper ball joints?
Ingalls and SPC both make adjustable rear ball joints...
Old Oct 22, 2009 | 05:51 PM
viper-blue's Avatar
http://cgi.ebay.ca/2-REAR-Upper-Ball...item5ad38cb62b
There are kits all over ebay. I have an adjustable ball joint kit on my car and honestly see no difference whatsoever between the front and rear ball joints. Whether they are different part number or not, they are the exact same dimensions.
Old Oct 22, 2009 | 10:06 PM
gstrudler's Avatar
4th gen is the same all around, 5th gen is different in the front (rear is the same as 4th gen).
Old Oct 23, 2009 | 02:08 PM
SKDRCR's Avatar
Awesome, thanks for the info guys
Old Oct 29, 2009 | 05:51 PM
Remiss's Avatar
yeah it works i changed both of my rear uppers without replacing the control arm ... dont think u can get them from honda tho
Old Dec 19, 2009 | 11:32 PM
notwerk's Avatar
New User
Hmm, I wonder if this means that Accord ball joints would work. Those e-bay ball joints are also listed for some Accord models: http://cgi.ebay.ca/2-FRONT-Upper-Bal...item5ad1f74c97
Did you just press them out of the control arm? I've got to change all the ball joints on a 93 lude, but I really don't want to have to swap out the control arms unless it's absolutely necessary. If I could pick up Accord ball joints from my local auto parts store, that would save me a lot of cash. Do you remember what ball joints you used and where you got them?
Thanks
Old Jan 6, 2010 | 12:33 PM
starbai's Avatar
I need to purchase some ball joints for my rear upper... I was considering doing the SPC adjustable but they sell two... one with a higher range of camber adjustment than the other... and i dont know which to get...
does anyone have any suggestions?
Or know if autozone will sell be just normal ball joints for the rear upper control arm?
I've been thinking about : http://www.iapdirect.com/product.php?productid=39851
to replace the upper ball joints on my front and rear... the problem is I dont know if I should get the "-1.5 - 1.5 degree" ones or the "1.5 - 3.0 degree" ones?
The car is dropped probably about 2" - 2.5" on ground control coils and tokico 5 way adjustables.
I dont think i really need a camber kit style ball joint, but searching a few parts places online it seems like buying just the ball joints by themselves are so expensive I figure I may as well do these adjustable style ones...
Old Jan 6, 2010 | 05:41 PM
minilogoguy18's Avatar
You can't get OEM ones by themselves, you have to buy the control arm and they will come with it. Reason being is if ball joints are pressed in/out more than twice they pretty much aren't gonna stay in anymore and the hole will become worn on the control arm. Get the ones that allow more adjustment, the rear gets very negative when dropped but don't think that it'll fix tire wear or anything like that though...
Old Jan 8, 2010 | 11:54 AM
xelocity's Avatar
sure it will
Old Jan 8, 2010 | 05:27 PM
Originally Posted by xelocity
sure it will
Sure what will??? There's like 3 different statements in my previous post.
B_Swapped93
Acura TSX
Jan 7, 2019 05:10 PM
ross2004
Jun 13, 2017 10:05 AM
pprowler6
Mar 10, 2012 11:14 AM
brotherparker
Feb 21, 2009 08:42 AM
Thrashed Civic
Jul 23, 2007 05:55 PM
