engine overheat
Old Oct 21, 2009 | 03:29 PM
duyfash0's Avatar
Default engine overheat
i have a b20 engine in a 99 hatch. just today when i was parked at a light, i looked at the hot/cold meter on the cluster and its all the way close to the H. when i start driving over 30 mph it goes down to the center like normal. when i park again it goes up to the H again.. what can be my problem?
Old Oct 21, 2009 | 03:31 PM
boostedteggy's Avatar
Default Re: engine overheat
its either ur low on coolant, ur hose is bad, or ur pump but mostly think ur low on coolant.
Old Oct 21, 2009 | 03:32 PM
Arcitekt's Avatar
MOB Mentality
you can check if none of your coolant hoses are leaking or your radiator fan could not be turning / sensor issue.
Old Oct 21, 2009 | 03:41 PM
3Pedals's Avatar
New User
Thats the route i would go. if the cooling fan isnt working that would explain why it gets hot at idle
Old Oct 21, 2009 | 03:43 PM
ferio252's Avatar
A radiator fan not turning would be a likely cause.
Old Oct 21, 2009 | 04:25 PM
sde780's Avatar
I would turn it off if it overheats, you don't want to blow headgasket/warp the head
Old Oct 21, 2009 | 04:40 PM
2kcoupedude's Avatar
I would first check the coolant level when the engine is cold "both radiator and reservoir". Second I would run it at 2500 rpms to warm it up to check if the cooling fans turn on and turn the right directions, lol I've seen it. Make sure you DON'T over heat it during the fan-cycle process!!! Then check for leaks at all hoses radiator and heater core hoses, The radiator, heater core, water pump, and Thermos stat. If everything is a go, I would replace the thermos stat, its cheap and quick.
Old Oct 22, 2009 | 12:02 AM
Lovin_My_E.G[G]'s Avatar
sounds like you blinker fluid
Old Oct 23, 2009 | 05:57 AM
DJ Alex's Avatar
My 99 hatch did the same thing yesterday, and i turned on the heater all the way and blasted it and it went back to normal...i was freaking out for a minute there.
Old Oct 23, 2009 | 08:03 AM
Jimster480's Avatar
it sounds like your low on coolant and your fan may or may not be working.
Old Oct 23, 2009 | 08:14 AM
chinochanginc's Avatar
air bubble in your coolant... fill up ur radiator and run the car w/0 the rad cap to bleed it
Old Oct 23, 2009 | 08:38 AM
gwl's Avatar
gwl
You still have a problem. Check your thermostat and the rad fan.
Old Oct 23, 2009 | 08:40 AM
shawn_crx's Avatar
Air in your system.
ef yu
Oct 22, 2010 12:45 AM
mycar95gsr
Honda Civic (2001 - 2005)
May 17, 2009 08:55 AM
pentaq
Feb 14, 2006 05:18 AM
r3v da t3g
Jul 28, 2005 07:51 PM
cnycivic
Mar 28, 2004 07:55 PM
