civic sturts/assembly 93vs99
Old Oct 21, 2009 | 02:17 PM
x_doug-x's Avatar
Default civic sturts/assembly 93vs99
will the whole shock assembly off a 99 fit a 93 hatch, if not, will just the strut fit? i talked to someone local and they think the only diffrence is the abs sensor but we're not possitive.
Old Oct 21, 2009 | 03:44 PM
EKSedAndy's Avatar
Default Re: civic sturts/assembly 93vs99
The fronts are basically the same and can be swapped (I think just a mount for the brake hose is different, but might be wrong). The rear though are different in that the EG (93) control arm bushings are wider than the EK (99) ones where the strut mounts to the control arm. You can use EG rear struts on an EK if you add some spacers, but you can't use the EK rears on the EG because the lower mount won't fit over the bushing.
deek25
Nov 16, 2013 05:18 AM
Ariddle25
11
May 3, 2011 05:58 AM
Vi3tsi06
Suspension & Brakes
28
Sep 9, 2010 10:05 PM
myEK=slow
Jun 23, 2006 09:40 AM
jdm_eg94
12
Dec 29, 2005 07:44 AM
