SH/Base wiring harness??
Ive been working on a 97 base that I bought a couple weeks ago, and I have a wiring issue that I can't figure out. The car was throwing CEL for primary O2, so I jacked it up and found that the primary o2 isn't plugged up...I began looking on the harness and couldn't find the 4 pin connector (C118). I pulled the harness out of the car and took off all the tape and couldn't find any cut wires. Where the ecu harness comes out at the strut tower the wires for o2 are there, but not on the engine harness side. The harness has the plug for atts, and one other unused plug at the stut tower (atts??). My question is do all 5g preludes have the atts plug? The helms manual looks like the primary and secondary o2 go the ecu on the body side of the harness not the engine harness. Does the SH engine harness have an o2 sensor plug? If it does I guess Im going to buy a new harness.
Yeah, they have a big plug for the ATTS sub-harness, but still have an HO2S connector. The ATTS sub-harness connector is pretty large, put up some pictures.
I've got my SH harness out of the car right now. Tell me exactly you want me to look at or take pics of and I can do that for you. Iirc from the last time I looked at the helms wiring diagrams, the O2 sensor wiring is not the same between Base and SH. Let me see if I can find it..
HatchSpeeD
May 23, 2008 05:17 PM
