vx wiring
hey I got a PM from you and I can't respond so here is my response:
Hi, sorry I didn't respond until now...
I made the jumper harness using a standard 8-pin honda engine harness plug (female) and a 4-pin O2 sensor Male plug for getting wires from the factory harness. your real LAF sensor has a variable resistor in the plug so it uses 7 pins to connect to the engine harness (including the 5 wires that go to the O2 sensor)
you can use your factory harness and ECU as long as you use the 4-wire O2 to get things running, thats exactly what I did before adding my subharness. this harness will go to the EGR, 5-wire O2 supplemental wires, as well as the EGR control box (you can harvest some parts out of I think 92-94 accords if you don't have the D15Z1 black box)
I hope this helps, if you have remaining questions feel free to ask! you can also email me directly at aaronhume@hotmail.com
Good Luck!
-Aaron
Originally Posted by optaire
Hello, i ran across your post. I started a swap with a d15z1 and a 93 eg/dx.I want to be clear on the 5 wire laf harness, also where did you get the plugs and pins?Is my non vtec distributor harness plug and play. Thank you
Good Luck!
-Aaron
fleabag
Jun 4, 2011 08:55 AM
