TPS p0123 HELP AHHHHHH!!!!!
lol, welcome to my post. entry is only 2 cent inputs... TIA
I have the h23v done, runs great. set the TPS because of a code.
with engine off, i have a solid ground, 5v, and .45 signal, 4.49v WOT
With it running its about the same, good ground, 5v, and .40ish and 4.40v WOT
why the hell do i have a code (P0123 TPS pedel position voltage high input) its not high, Im looking at it.
Blah, help please
Your 2 cents?
Blah, help please
Your 2 cents?
does your car ever buck or anything when you're driving it? I've had an ongoing tps code problem for about 2 years... it's the biggest bitch... I've done everything
Im having a very similar problem right now in my 2000 JDM OBD2 GSR teg! TPS code is present, and it idles high at about 1500, and burns a tad rich, enough that i can smell it. I checked the voltage and its good and within range, and i cant figure it out!!! any help or ideas??
yea< i went to check out bangher4$ car. I dont get it either. wires are all correct and voltage is all right. why would he still get the code?
.456 and 4.44 with key on
WTF
WTF
h22civ
10
Dec 12, 2006 01:54 PM
