oil leak coming from somewhere between the block
Old Oct 20, 2009 | 10:06 AM
jeremyrocksursox's Avatar
Default oil leak coming from somewhere between the block
i just found it today when i went to go change the oil it seems to be right below the first exhaust port, right where the top of the block and the bottom of the block connect, is there a gasket there?
Old Oct 20, 2009 | 10:10 AM
Hanmin's Avatar
Default Re: oil leak coming from somewhere between the block
Headgasket.
Old Oct 20, 2009 | 10:13 AM
dammit, alright you for sure?
Old Oct 20, 2009 | 10:14 AM
38genesis's Avatar
100% sure
Old Oct 20, 2009 | 10:17 AM
alright, how much do they run for?
Old Oct 20, 2009 | 10:22 AM
i found a websitre: http://www.acuraoemparts.com/delray/...All&vinsrch=no
would it be in Kit B?
Old Oct 20, 2009 | 10:36 AM
also, am i able to drive my car around or do i have to wait until it can get changed?
Old Oct 20, 2009 | 10:41 AM
38genesis's Avatar
yes you can, bring a liter with you so you can top up the oil that you lost.
Old Oct 20, 2009 | 10:43 AM
ok, thanks
Old Oct 20, 2009 | 11:24 AM
i have another question too, what all am i going to need for the repair?
i also plan on replacing the valve cover gasket too while its off. is there anything else i should also replace while the head is off?
and do i need to buy any special sealant?
Old Oct 20, 2009 | 11:39 AM
38genesis's Avatar
go to your local auto store and ask for valve gasket sealant. you can use that for you headgasket too aswell, but do only the odd corners.
Old Oct 20, 2009 | 01:50 PM
John M's Avatar
hahahaaha. i love how people jump to conclusions.
mots motors get dirty like that.
do a compression and leakdown test
chec ur coolant and see if it is milky
check to see if it is overheating.
dont just jump to conclusions
Old Oct 20, 2009 | 03:57 PM
its just weird because it wasent like that until after i got home from school today, and it looked fresh
but my coolant looks fine
i just replaced the coolant because it has been overheating the past 2 weeks because of a bad radiator switch, plus i did a totaly cooling system replacement with new fan, radiator, hoses and thermostat. so i finally got the overheating under control lol
and how do i do a compression and leakdown test?
Old Oct 20, 2009 | 04:01 PM
ferio252's Avatar
Werd For me this happened when I painted my valve cover and didn't reapply the gasket correctly.
Old Oct 20, 2009 | 04:02 PM
John M's Avatar
get some better pics
Old Oct 20, 2009 | 04:07 PM
93egSLEEPER's Avatar
that leak looks too small for it to for sure be a head gasket. usually if your getting a head gasket leak you will have other problems that accompany it.
Old Oct 20, 2009 | 04:08 PM
sde780's Avatar
Could have blown your headgasket from overheating it
Old Oct 20, 2009 | 04:45 PM
i can't get much better pics but ill try tomorrow when its light out
ValleySyder
Aug 24, 2009 06:44 PM
92integraVTECgsr
Sep 30, 2008 04:00 PM
all-mtr-teg
Sep 11, 2007 05:17 AM
kyle h.
Oct 7, 2003 10:02 AM
redline201
Feb 2, 2003 10:16 PM
