oil leak
oil leak
im leaking oil where the head meats the block
right about where it says the engine code (b16a)
think its a headgasket ???
its not much at all
but im boosting soon so i need to take care of this
its not much at all
Unceasing Measure
Re: oil leak (redline201)
There's not much else it could be if the oil is coming out betwixt head and block. Make sure it's not dribbling down from somewhere else. If your finds are conclusive, replace that bastard with a 2mm gasket
Re: oil leak (Archidictus)
...the oil is coming out betwixt head and block....
Thanks someone finally had the same problem i had. Hey where can you get a Headgasket from for a 94 D16z6 engine? And what kind should i get? I saw 2mm..
-alex-
-alex-
swizz977
49
11-20-2011 03:09 PM
Sr420Det
04-16-2011 02:55 PM
