Transmission & Drivetrain Gearboxes, Differentials, Clutches
Loud Squeal/whine when 5th gear is engaged
Old Oct 19, 2009 | 04:28 PM
odidipissuoff's Avatar
Icon3 Loud Squeal/whine when 5th gear is engaged
Alright, so the other day on the way to class i noticed when i shifted into 5th gear and released the cluch that a loud squeal/whine started. My car sit in my yard for 4 days while i was on vacation, my transmission fluid was very low. So what did i do to my car?
I searched and couldn't find the answer.
Old Oct 19, 2009 | 04:31 PM
Aquafina's Avatar
Default Re: Loud Squeal/whine when 5th gear is engaged
Cooked it.
Old Oct 19, 2009 | 05:09 PM
Originally Posted by Aquafina
Cooked it.
Good answer.....
Old Oct 19, 2009 | 05:20 PM
Aquafina's Avatar
You asked what you did and I told you. Low fluid = trans gets very hot = its cooked.
Would you like me to lie and tell you nothing is wrong with it?
Old Oct 19, 2009 | 06:51 PM
No, i would like an elaborated answer, as the one you just posted. It's only in 5th gear, and it still drives, shifts, the same just has the squeal/whine. Did i cook only 5th gear? or a bearing or what? I've been driving in since tuesday with the noise.
It just seemed that you were being a smart *** to me, i apologize. Thanks for your help.
Old Oct 19, 2009 | 09:27 PM
Mista Bone's Avatar
D Tranny Guru
It's FAWKED!
You won't until it is torn apart, but you continued to drive on it......not a smart idea.
Old Oct 20, 2009 | 12:31 PM
Originally Posted by Mista Bone
It's FAWKED!
Thanks for the reply, do you recommend tearing it apart myself or paying someone to do it?
Old Oct 20, 2009 | 01:38 PM
Aquafina's Avatar
I wasn't being a smart *** and generally aren't unless you ask for it. Just a short and to the point answer as I browse a lot of forums on top of running my business.
I'd have someone else do it as it seems you don't have the knowledge to do so and inspect everything (no offense). How far are you from Lexington or Knoxville? Either Bone or myself would be your closest options.
Old Oct 20, 2009 | 10:00 PM
night's Avatar
shaft end bearing is probly trashed. the whole thing needs to be cleaned out.
standards are very simple once you just sit down and look at it, but it is not something to do if you don't have access to tools/shop
Old Oct 21, 2009 | 08:42 AM
Aquafina's Avatar
If it got hot enough to kill a bearing, the trans is done.
Old Oct 21, 2009 | 11:50 AM
I'm 2 hours away from Lexington, and a little over 3 away from Knoxville. I contacted a local Transmission shop and have him look at it.
Sorry again about the previous post, and i appreciate your advice and insight!
Old Oct 21, 2009 | 11:56 AM
Evs-One's Avatar
Solbros Owns Me
5th gear is pretty far from the oil galley, so low on oil can overheat the needle bearing for 5th gear on the mainshaft. OR, you have a chipped tooth on the gear causing whine...one or the other.
This was a 99 Civic Si....there was MAYBE 1 pint of MTF in the box. Customer drove on freeway for several minutes and it killed the 3rd gear. The needle bearing seized the gear to the collar, and the collar seized to the shaft. This trans got HOT...
I can't remove the collar with a vise and a sledge...
Old Oct 21, 2009 | 01:34 PM
I'm thinking i have a similar case, just with 5th gear. How much estimated repair cost? (paying a shop to do it)
Old Oct 21, 2009 | 02:03 PM
Evs-One's Avatar
Solbros Owns Me
ABove cust was 1450 with labor, Exedy clutch, 3-4 sleeve set, collar, gear, bearings, seals, needle bearings etc. And a 5-R set too. And some misc parts, hot tank, etc
Old Oct 21, 2009 | 02:35 PM
wow, I hope thats not whats wrong with mine I'm taking it tomorrow when i get in from class to get it checked out. I will post when he tells me what is wrong with it.
Old Oct 26, 2009 | 05:57 PM
So it's in the shop, the guy is supposed to call me some time this week and let me come check out whats wrong with it.
275 for labor (Taking tanny out, spliting it, putting it back together and then putting it in)'
Still owe for parts, and labor to fix it. Still don't think it's a bad price?
Old Oct 27, 2009 | 04:02 PM
Evs-One's Avatar
Solbros Owns Me
Not at all....even at a cheap labor rate of say 50/hr, you're still a little over 5 hours labor into it, which is very reasonable, if not great. Make sure you dont get raped on parts!
Old Oct 27, 2009 | 04:18 PM
Aquafina's Avatar
Trans will have over 5 hours alone (not including removal/install) if the shop does it correctly.
Likely cheaper to just replace the trans, see my earlier posts for reference.
Old Oct 27, 2009 | 06:17 PM
He told me he wouldn't buy any parts until be contacted me about fixing it with the price. And he would charge me anymore than 275 if thats the route i wanted to go, instead of paying him to fix it.
Anyone know of a place i could get a cheap Tranny if i need to go that route?
Recaan
Aug 7, 2016 12:24 AM
92eg6lsvtec
Jul 9, 2008 07:08 PM
green93
Jan 5, 2003 07:40 AM
Cyber ITR
Jul 22, 2001 07:50 AM
