Suspension & Brakes Theory, alignment, spring rates....
Integra/Civic front sway bar compatibility
Old Oct 19, 2009 | 03:18 PM
The spongeness's Avatar
Default Integra/Civic front sway bar compatibility
Will a '94-'01 Integra LS stock front sway bar fit a '92-'95 Civic? I unfortunately got the wrong sway bar from a 98 EX that won't fit on my 92. I have heard that a DC teg front sway bar will fit, but I have also heard they fit '96-'00 civics which seems to conflict with the '98 bar not working on my '92. Can anybody confirm what's correct?
Old Oct 19, 2009 | 05:41 PM
phunhaus's Avatar
Default Re: Integra/Civic front sway bar compatibility
Yes it will assuming you got the sway bar-compatible front LCAs.
Old Oct 19, 2009 | 05:44 PM
Yes, the front LCAs are from an EX. How do 94-01 teg front sway bars fit EK civics as well if an EK civic bar won't fit my eg?
Old Oct 19, 2009 | 06:18 PM
Egezzy's Avatar
Spongebrad Squarepants
also you will need integra endlinks.
and the reason the 96-00 arb wont fit would be due to different bends and twists under the chassis.
Old Oct 19, 2009 | 06:20 PM
Some integras use the same endlinks it looks like, is it only Type Rs that use the 90 degree endlink? The 95 integra bar I'm looking at seems to be the same straight link as the civic.
Yea I found out that the 98 EX sway bar wouldn't fit because the bend for where the D bracket attaches is not close enough to the frame, the bar needed to be at least 1.5" closer to the frame at those points and just won't work.
Old Oct 20, 2009 | 05:58 AM
blaze the chemi's Avatar
http://www.jdmuniverse.com/forums/view_ekswaybars.html
^^^^ good information
Old Oct 20, 2009 | 07:04 AM
I've seen that, unfortunately it doesn't answer my question. It looks like a teg bar will fit though.
Old Oct 20, 2009 | 04:04 PM
Egezzy's Avatar
yes it will fit and yes the endlinks are different.
Old Oct 20, 2009 | 04:16 PM
Not all integras have the right angle end links. Some have the exact same straight-through style as the civic.
Old Oct 20, 2009 | 06:06 PM
Egezzy's Avatar
Icon2 Re: Integra/Civic front sway bar compatibility
hmmm. i have both a gsr arb and ex arb along with the matching endlinks. and the endlinks are different along with the angle of the mounting part of the bar. but apparently you already know the answer....
Old Oct 20, 2009 | 06:29 PM
Like I said, some integra endlinks, and thus sway bar ends, are different than others. I'm not sure what the difference is, but I want to say '94-'97 are one type and '98-'01 are another. Both bars will work but you will need endlinks that match the bar.
Old Apr 30, 2023 | 05:53 AM
HOTSHIZZ GAMING's Avatar
would an EG 92-95 sway bar fit an Integra ?
jdmsir4dr
Suspension & Brakes
Apr 27, 2015 07:56 AM
3Rd GeAr PuLl
May 28, 2007 06:45 AM
cvccjdm
Sep 29, 2004 01:14 PM
DreamSpeed
14
Oct 25, 2001 09:57 AM
