Integra Alarm Hood Pin
Old Oct 18, 2009 | 07:56 PM
xrdriver's Avatar
Default Integra Alarm Hood Pin
I am installing an alarm into a 2000 Integra GSR sedan. I would like to not have to use the hood pin that came with my alarm. They stick out like a sore thumb and they don't seem to last long anyhow - the wires fall off or they get corroded.
Does the Integra come with an OEM hood pin? I was looking around and found this info in a few places:
| HOOD PIN|yellow/red |- |drivers kick panel |
My car did not come with a factory alarm, the plug is taped up in the kick panel. I cannot find a yellow/red wire up there so I thought I'd ask the experts...
Old Oct 18, 2009 | 08:14 PM
KRock459's Avatar
Default Re: Integra Alarm Hood Pin
I dont think models w/o alarms where pre-wired with a pin sw. installed, and if I remember, the pin sw. is built into the hood latch. There are higher quality hood pins available, but you can use the included pin sw and try to protect it with some dielectric grease.
Kirk R
Old Oct 19, 2009 | 04:13 PM
xrdriver's Avatar
Kirk R
OK, thanks man. I wonder if I can retrofit something to the hood latch?
Old Oct 19, 2009 | 09:57 PM
Tekkaboy's Avatar
I made a little bracket and mounted the DEI hood pin near the battery and fuse box at the passenger side firewall. This way it is more protected from weather and triggers if a thief peels the corner of the hood back to get to the battery.
Old Oct 25, 2009 | 10:19 AM
suspendedHatch's Avatar
You can order the OEM hood pin from Acura. Part number is 08E49-ST7-200G
Old Oct 25, 2009 | 09:06 PM
xrdriver's Avatar
Thank you!
Old Oct 25, 2009 | 10:26 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I allways put it on the firewall and it looks factory. I never have a problem with the dei ones. Just hit them with wd40 every now and then. I show you pics later.
Old Oct 26, 2009 | 08:03 AM
If you use an aftermarket hood pin, make sure you install it so that it wont get wet. They rust easily and then stop working. Also, water can even cause a false trigger! I've dealt with both problems extensively so take my word for it (was never a problem for me when I was living in So CA).
If you use a backstrap and some metal tapping screws, you can extend the hood pin away from the outer edges of the hood. Just be sure to brace the backstrap (get creative). Difficult to make it look clean IMO.
Odessa
Audio / Security / Video
Jul 14, 2004 04:10 AM
chris408
Apr 22, 2003 11:24 PM
GoLowDrew
Mar 29, 2002 04:02 PM
non-car driver
Jan 30, 2002 06:12 PM
mickey513
Oct 29, 2001 02:31 PM
