b series swap axle?
Old Oct 18, 2009 | 06:19 PM
BigSorn's Avatar
Default b series swap axle?
Hi, I have a 99 hx with a b16a2 that I bought that way. Long story short I need a driverside axle, and I can't seem to get the right one. I just need the axle, not the intermidiate shaft. I've tried a 99si, and a 99hx. No luck.
So what axle do I need?
Old Oct 18, 2009 | 09:46 PM
civic_r87111's Avatar
Default Re: b series swap axle?
U should b able to use any b-series axles. Is ur intermidiate shaft an inny or an outty and what was the 99 Si axle and inny or an outty?
Old Oct 19, 2009 | 04:45 AM
BigSorn's Avatar
The intermidiate shaft has a female end, and the si axle I got also had a female end on it.
Old Oct 19, 2009 | 05:15 AM
94EG8's Avatar
Seagull Management
'90 - '93 Integra.
Old Oct 19, 2009 | 05:20 AM
speedooo's Avatar
sounds like they used a 90-93 integra halfshaft, you need the corresponding axle for that halfshaft
Old Oct 19, 2009 | 05:31 AM
BigSorn's Avatar
So when i go to the partshouse, I just ask for a 90-93 integra? What's trim modle(like si), or does it matter.
Old Oct 19, 2009 | 06:08 AM
ek4_b16a's Avatar
Get an ls one. Why not swap it out for the correct one? Change out the half shaft and the axle seal and you'll not need to worry about this issue in the future. It really isn't an issue. Just get an ls axle and you're set
Old Oct 19, 2009 | 06:12 AM
RyanA's Avatar
Hell, I'd pull the intermediate shaft anyway just to make sure the correct seal is in the trans. Could be that the wrong seal is in for that shaft since it's a cable Ishaft on a hydro trans (right?) I'm with others; get a 94-01 Integra or 99-00 Civic Si intermediate shaft and axle and you'll be set.
Old Oct 19, 2009 | 06:18 AM
speedooo's Avatar
Why is anybody talking about a god damn output shaft seal? He needs an axle that complies with his halfshaft. Get a 90-93 integra axle, any trim works. ls/gs/gsr...
Old Oct 19, 2009 | 06:29 AM
BigSorn's Avatar
Thank you.
exactly what I needed to know.
Old Oct 19, 2009 | 10:03 AM
I have used both intermediate shaft with both axle seals and never had a problem, they interchange.
Old Oct 19, 2009 | 12:15 PM
RyanA's Avatar
Don't know about everyone else but I'm talking about it because he has a HYDRO trans with a CABLE intermediate shaft. We all know that the ID of the seal is different between the two. I'd rather have him verify the correct seal is in the trans so his next topic is not "My transmission is leaking everywhere! Help!!" That's MY reasoning behind it. YES, you can use whatever Ishaft you want as long as you have the matching axle. HOWEVER, you also have to have the correct seal in the trans for that shaft.
I said it before, I'll say it again: You don't have an axle in there yet so the Ishaft is only 3 bolts to pull out. Measure the OD of the shiny sealing surface on the Ishaft. Measure the ID of the seal. It should measure SLIGHTLY smaller (maybe a few thousandths). If it is bigger, you need to swap the seal.
Old Oct 20, 2009 | 03:53 PM
Well I have used both types of Ishafts with both types of trans and I have never had a leak, never changed a seal either, IDK!.
Old Oct 20, 2009 | 06:01 PM
RyanA's Avatar
IDK either... Here are the part numbers AND DIMENSIONS of the seals straight from Acura:
021 91205-PL3-B01 OIL SEAL (40X56X8) (ARAI) 1 1992 INTEGRA 10.50 7.88
019 91205-PL3-A01 OIL SEAL (35X56X8) (ARAI) 1 2000 INTEGRA 9.37 7.03
Now, no one has to be a rocket scientist to figure this one out. The 1992-1993 Integra uses a 40mm inside diameter hole for the intermediate shaft, 56 mm outside diameter for the case, and it's 8 mm thick. HOWEVER, the HYDRO Intermediate shaft seal is 35mm inside diameter hole for Intermediate shaft but it's still the 56 mm OD and 8 mm thick. SO, I guess if ACURA thought it was important enough to change a seal, I do too.
So, 5 mm difference in the inside diameter of the seal. If it's too small, you'll stretch the seal and the tensioning spring will pop off inside the trans. Probably not a good thing to have a piece of metal going around in there. If it's too big, well, it will leak. For those of us (like me) that have no clue what 5 mm is without looking it up, it is 3/16". That is almost 1/4"!!! Which means if you have a small Ishaft but the big seal, you will have about a 1/8" gap all the way around. I'm pretty sure fluid will be able to escape out of a gap that large. Trans fluid has surface tension but not THAT MUCH.
Old Oct 21, 2009 | 09:40 AM
10.50 7.88 and 9.37 7.03, what r those # for?
Old Oct 21, 2009 | 01:39 PM
speedooo's Avatar
Who the hell cares...he needs to knew what axle to use, the output shaft seal is completely unrelated to the topic. If you want to make a thread about, go do that, but as far as this topic goes, the kid needs a da axle. I personally have a da halfshaft on an 01 gsr trans with a da axle in my 94 civic and there are no leaks. Eat me.
Old Oct 21, 2009 | 01:45 PM
We already told the kid what axles he needed so now he knows, the questions has been answered and the problem fixed.! Now we can use the thread for more advanced topics related to the original post. If u don't like it then don't click the headline!!
Old Oct 21, 2009 | 04:04 PM
RyanA's Avatar
Just list price and cost from AcuraOEMParts...
Old Oct 22, 2009 | 02:34 PM
speedfreak44's Avatar
i have got a complete axle set up for b series.... left and right with c.v joints and intermediate shaft... $200
Old Oct 23, 2009 | 05:19 PM
BigSorn's Avatar
Already got it. Doesn't leak, fits fine. I think if there was a 1/8th inch gap, I'd notice it. I don't know if they changed the seal, but the 92 integra axle in the intermidiate shaft fits perfect eith NO LEAKS! Now would someone help me get the car running right in my other thread? Haha
hardcore97
Transmission & Drivetrain
Dec 6, 2012 01:11 PM
integrawow
Jul 2, 2007 02:20 AM
JSpin
16
Aug 19, 2006 02:16 PM
jacoop86
Aug 11, 2006 04:07 PM
Burlyirishdude
Apr 23, 2006 10:28 AM
