88-91 civic / crx tracton bar crosmembers avalible
Old Aug 29, 2002 | 04:14 PM
jim helms's Avatar
Default 88-91 civic / crx tracton bar crosmembers avalible
new from jimfab.com the long awaited crossmember replacement. eliminate wheele hop, improve 60 foot times and tighten up your front end with a new crossmember from jimfab.com. made from 4130 chromeoly tubing and constructed to be bulletproof. this crosmember is what you need to eliminate the inhearit wheele chatter the 88-91 civic recives when it is pushed. Even stock motor cars will benefit from this. this crossmember also leaves plenty of extra room for a 4-1 headder or a turbo setup with a large downpipe. The motor mount is located in the stock location, and it will work with most of the current B-series swaps. some older swap kits hold the motor too far forward and clash with the oil pan. we also offer the crossmember without the motor mount attached. recentley reduced to sell at $350.00 compare to the competition at upwards of $900.00. we only use the best heim joints, grade 8 bolts, and material. check them out at jimfab.com or ag-engineering.com. the bars are hand made in the u.s.a. by Jim helms himself.
Old Aug 29, 2002 | 04:24 PM
91sifreak's Avatar
New User
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (jim helms)
Wow, 350 compaired to the Z10 radius rods for 500.00 looks good, but will it hold up as well as the Z10. There is a guy running around here with a b20/vtec and they handle slam shifting. The weldson this unit look beautiful, I know if they hold up that well, I WANT ONE.
Old Aug 29, 2002 | 04:29 PM
SpeedMonkeyRacing's Avatar
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (91sifreak)
same here...i would buy it...how 'bout we get a groupbuy going..and make it 350 shipped?
Jeff-
91sifreak's Avatar
New User
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (Corporal-Jeff)
Hmmm, now that would be a deal.
Old Aug 29, 2002 | 05:02 PM
NikoZai's Avatar
why at the bottom of the JIMFAB article on it do you put "NOT RECOMMENDED FOR STREET USE" why the hell not?!
Old Aug 29, 2002 | 05:55 PM
customx_'s Avatar
New User
https://honda-tech.com/zerothread?id=266363
Old Aug 29, 2002 | 07:33 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (mindtrix)
note:
AG-Engineering is at http://www.ag-eng.com
Thanks.
Old Aug 29, 2002 | 07:41 PM
.nate's Avatar
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (B18C-EJ1)
92-95 civic raidiator mounts?!?!?
Old Aug 29, 2002 | 08:04 PM
EF_LSVtec's Avatar
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (NikoZai)
Yeah, whats up with "Not recommended for street use."
Old Aug 29, 2002 | 09:21 PM
EF_LSVtec's Avatar
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (EF_LSVtec)
I noticed it didnt have a front mount location for the tranny like the one from Place's
Old Aug 29, 2002 | 10:07 PM
Mugen Dom's Avatar
legal reasons i think but does z10 sayt anything about street use??? looks like the one some guy was showing a few weeks back
Old Aug 29, 2002 | 10:53 PM
chhuong's Avatar
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (jdmb18hatch)
Jim I didn't see a email for you, so i guess i'll just post it here. I got a few questions.
Is it extra for the front mount on the crossmember?? Also will the front mount that you sell for the 88-91 civic work on a b-series motor, and fit your crossmember??
What color are your strut bars, and will the ones designed for the 90-93 teg, fit a 88-91 hatch??
And if i buy all those things from you will you give me a discount??? I'm interested in the crossmember, front mount, and front and rear strut bars!!!
Old Aug 30, 2002 | 08:48 AM
91sifreak's Avatar
New User
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (chhuong)
Yeah that is important to me is the use of the front torque mount on a b16a, it made a world of diffrence in the launch ability of my car. If it has a front mount bracket then hell yeah I will take one.
Old Aug 30, 2002 | 10:53 PM
.nate's Avatar
92-95 raidiator mounts!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 13, 2002 | 04:19 AM
Arturbo's Avatar
Better than steak
25 Year Member
Its only a disclaimer.
art
Old Sep 13, 2002 | 04:26 PM
Bnjmn's Avatar
How big a deal is it that the jimfab/AG racing bars only have 3/8" of pre load adjustment and you have to jack up the car and undo one end of the radius arm to adjust? How useful is the pre-load adjustment? Exactly what does it do?
Thanks
Ben
Old Sep 14, 2002 | 07:00 AM
1's Avatar
Default Re: 88-91 civic / crx tracton bar crosmembers avalible (Bnjmn)
you have mail
ESP.net
Nov 24, 2007 04:55 PM
jim helms
Sep 18, 2002 08:53 AM
BuCU
Jun 24, 2002 03:03 PM
