F20B Cams n H22 head
I wouldn't do it because I've heard that they're the same spec as the Type S cams which will eat away the rocker pads. There's a thread on here about that issue. Something on the USDM head that causes this which I forgot. Just a heads up man.
Could it have to do with the altered valve angle in the type S head? Maybe the rocker arms are slightly longer too? But yea i have also heard that it causes excessive wear on the rocker pads and the cam lobes.
But, I heard some ppl using them with no problem though; may be due to using a JDM head? because I've heard that JDM H22s have aggressive cams than the USDM H22s(Don't quote that on me though) I don't know. Just a thought.
So you guys argue about the increased rocker wear huh. Have you guys thought about the effects from even more aggressive cams like some Pro 2's or 3"s? The rocker wear isn't from the slightly more aggressive cams; for the most part anyways. Do a search on the H22 rocker arm wear. It happens with OEM cams as well.
Yes, naturally rocker pads wear on a stock motor (which is partly why valve clearance/lash goes out over time), but its not just the pads that wear, the cam lobes wear too. Cant expect anything less from two metal components colliding at a high rate of speed for many km's (with oil to lubricate).
The real debate is whether there really is a significant rocker arm length/height/position change on the type S engine (JDM) to accommodate the more aggressive cams. I know that the newer P5M heads have altered valve seat angles (from 60' to 45' or something of the sort) to enhance air flow, that might change the position of the rocker pads, which could also be why there is enhanced wear on the P13 head's pads with type S camshafts. Any one able to shead some light on this?
From what I've read, the rocker wear issue is due to less zinc being in modern oils(I think it's zinc). But their's not any solid proof yet. Also, the increased lift/durantion will wear out your rockers faster, but not as bad as you guy make it out to be.
Why would their need to be more room on the Type S head? Like I said, people run ALOT more aggressive cams in their P13 heads.
if you go to the all motor thread this matter was recently brought back up after being dead for some time. and yes zinc does help fight wear on parts. bisimoto makes some improved rockers for h22s. and i believe endyne also has their own treatment for h22/b18 rocker pads
lol.... i didnt even realize that was you man. its good that somebody else is trying to keep the thing going. one of these days we'll get to the bottom of this problem. when i have my engine done and running with new cams, i will probably pop the valve cover off once a month just so i can monitor any irregular wear.
BIGblock97
Jan 11, 2007 12:21 PM
