Adjusting your idle
Old Oct 17, 2009 | 02:47 PM
robcivic559's Avatar
Icon6 Adjusting your idle
Adjusting your idle for da 1990 da 4 door gs to ls swap on it idle just goes up and down have the jdm ls throttle body it but use the old throttle body for my friend da need help
Old Oct 17, 2009 | 02:53 PM
ek-g6's Avatar
Default Re: Adjusting your idle
Make sure you properly burped or bleed out the coolant system. Check for any vacuum leaks, and to adjust idle, turn the idle screw on the tb.
Old Oct 17, 2009 | 03:02 PM
the car engine cool it just the idle i want to use the the new one but the plugs and hoses are different from the gc to ls so i use the screw setting still nothing on the tb
Old Oct 17, 2009 | 03:05 PM
ek-g6's Avatar
Which LS motor are you using 94-01?
Old Oct 17, 2009 | 03:16 PM
a jdm ls 94 to 01 b18b non vtec
Old Oct 17, 2009 | 03:19 PM
ek-g6's Avatar
This should help.
http://www.team-integra.net/forum/di...g+Common+Topic
Old Oct 17, 2009 | 03:31 PM
thanks man i need that help hit me up
Old Oct 17, 2009 | 03:34 PM
ek-g6's Avatar
If you still need help lmk, I stay around the clinton and cedar area
Old Oct 17, 2009 | 03:49 PM
i know were your at right know i'am out here in i.e. workn i didn't find work out there in the no so i came out here and got a good job i live on herndon in pinedale time are hard so i came out here to make money thanks
TheAngryGinger
May 15, 2011 12:08 AM
zoidburg
Dec 21, 2010 06:36 PM
BiGcAmBoDiAnSaUsAgE
Apr 8, 2007 09:24 AM
vtecda
Aug 15, 2005 07:41 AM
93H22A
Nov 4, 2001 02:44 PM
