94 Civic Front Wheal Bearing Change Write Up
Old Oct 17, 2009 | 06:43 AM
123HondaFan's Avatar
Default 94 Civic Front Wheal Bearing Change Write Up
I looked and looked for for info about replacing the wheel bearing and found nothing so I picked up a bearing and rented a 4 pc axle nut kit from Autozone so I could do the work and post a write up for later use.
Wheel Bearing at Autozone= $33.99 same as $44.99 just check the part numbers and dont waste your money.
Axle Nut Kit at Autozone= $45.99 and you can take it back when your done nd get every penny back plus if one breaks the replace it for free.
Doing the work later today and will post 100 pics of the process.
Pics at http://viewmorepics.myspace.com/inde...lbumId=3080554
Old Oct 17, 2009 | 06:51 AM
batallic's Avatar
Default Re: 94 Civic Front Wheal Bearing Change Write Up
u need a press, theres something called a hub shark u can remove the bearing on the car with the shark
Old Oct 17, 2009 | 07:19 AM
ya im going over to a friends house and hopefully we can use his vise if not i'll try a BIG hammer and a block of wood hopefully it will not come to that tho
Old Oct 17, 2009 | 08:52 AM
rcharr2k9's Avatar
Good Luck!! You are going to need a 50 ton shop press with the proper sized driver die or you WILL, not CAN damage not only your new hub bearing, but the "spindle" assembly as well.
Old Oct 17, 2009 | 09:17 AM
batallic's Avatar
50 ton is overkill i did it with a 12 ton
Old Oct 17, 2009 | 09:19 AM
batallic's Avatar
buddy yur have to press it in through the inner race or else yur guna **** up yur bearings
Old Oct 17, 2009 | 09:30 AM
rcharr2k9's Avatar
Just going by what we use here at the shop. Besides, rather have overkill than underkill!!
well turns out im ot working on it till next weeken and hes got a press so we will see
Old Oct 17, 2009 | 09:40 AM
rcharr2k9's Avatar
COOL!!!
You should. if you can, do extended studs while you have them out.
civicsi98
14
Mar 14, 2017 09:13 AM
jdm_ek_noob
53
May 28, 2014 02:19 PM
jdmcivicracer89
10
Nov 7, 2010 04:48 PM
TurboEG6OneFive
Suspension & Brakes
Dec 26, 2009 07:46 PM
y49crxsi
Jul 14, 2004 10:51 AM
