i need help on a engine swap
hey guys! i have a a
97 acura cl with 2.2 engine..the guy sold me the car with blow motor and i swap the motor to 2.3 but the wires doesnt plug in..what should i do? should i take the wire harness under the dash where i took the 2.3 motor from? plz help me..thanx guys
well if i take the wires under the dash which i took the motor(new motor) from and it would just plug in..i was gonna use the engine harness from the blown motor but the distributor plug dont look the same...thanx
uhm swap the sensors from the 2.2L onto the 2.3L and while you are at it put an exhaust header on it to get some small gain (10hp) while you got the engine out of the car.
plugs are most likely different for the sensors on a f23 motor
both are cable driven systems so I believe that you don't need to swap intakes but if the TB's don't swap then you might have to .....
yes swap sensors and use wireharness from blown engine
i think that i can help you and i think you can help me!! I have a 98 acura cl with a h22a motor swap. I kept MY F23 (2.3) ENGINE HARNESS (IT IS STOCK WITH ALL THE CONNECTORS.....I HOWEVER NEED THE 2.2 ENGINE HARNESS OUT OF THE 97 CL (BUT ONLY IF IT IS A MANUAL ENGINE HARNESS) SO, I WOULD BE UP FOR AN EVEN TRADE IF YOU ARE INTERESTED.
