'00Civic Si Vaccume hose and Tanny issue!!!
Ok. This just happened. For some reason It has been idleing lower then usual and it goes up and down.... And for some reason 2nd gear is just being a bitch to get into. I am a new stick driver.... 1 week in 2 days. But i know how to drive it. I have never stalled or grinded the gears. Only once did i put the car into and and not 4th. But i was just going to down shift. I have some pics of what looks like a leak of the oil in the tranny from a bad gasket.... I ahve pics if that will help..so i wants on the gas. Sorry for bad grammar. I am in a hurry. The F means front, R Rear, P passenger side, D Driver side...
Also.... This is a vacume hose that seems to be well not connected. What is it for ? Thanks...
Thanks a TON!!!!!
Thanks a TON!!!!!
whats going on man. ahh my civic recently been idleing low as well. i turned up the idle abit but my idle also just jumps. it will go up and down up and down and then sometimes stall. someone told me it as the throttle body? i know vaccum is a big thing in the idling but thats what someone told me cause my vaccum is fine i think. i tried cleaning the throottle body and it got alil better but my civic idles alil high right now. i think the part u pointed out for the vaccum i think i dont have a hose there either? ill look
I am going to get new plugs and plug wires. And while I am there I am going to get the check engine light code looked at... Isn't that free.
WOW, Idk what all that was but it sounded like the blind leading the blind, lol. It could b ur clutch is going out or ur 2nd gear syncro's or maybe even ur just low on trans fluid. Looks like ur passenger side axle seal is leaking too. Also the circle u have labled as A is the slave cylinder bleeder valve not vacume. The low idle could b caused by a list of things too.
Thanks lol. The clutch feels fine, so I think the 2nd gear syncro is the issue and low tranny fluid. And as far as it leaking I know I will have to take it to the shop cause i don't have the space.
philkehn
Sep 8, 2006 03:13 PM
Louis53123
Jul 15, 2006 06:27 PM
Civicman86
Oct 23, 2005 08:59 AM
