Q about rims
Old Oct 15, 2009 | 12:48 PM
ninjadancer's Avatar
Default Q about rims
So my brother and I swapped his 15" rims for my steelies and every time i make a turn or hit a bump it makes this nasty rubbing sound obviously the tires hitting is there any way to eliminate that or should i just trade them for smaller rims? Im sporting a 92 civic hatch
Old Oct 15, 2009 | 12:49 PM
MHDesigns's Avatar
Default Re: Q about rims
It's probably too big of a tire. What is the tire size? Rim offset too if possible.
Old Oct 15, 2009 | 12:51 PM
205/55 R15
Old Oct 15, 2009 | 01:17 PM
ferio252's Avatar
^ Hmm. Possibly to wide of a tire? I would go with 195/55/R15? bump for possible suggestions.
Old Oct 15, 2009 | 01:20 PM
i was thinking the same thing cause when i ride alone it doesnt do it as much but if another person is in the car with me it sounds really nasty and annoying
Old Oct 15, 2009 | 01:35 PM
eg grom's Avatar
Its gotta be the tire size
Old Oct 15, 2009 | 01:55 PM
Arcitekt's Avatar
MOB Mentality
are you getting this noise from the front or rear?
im not sure what its called but the plastic cover thats above your tire behind the fender, you might want to check that its not loose or hanging that it rubs everytime you turn your wheels
Old Oct 15, 2009 | 02:01 PM
it sounds like its coming from the passanger side rear it happens on bumps and sharp left turns then it smells like burning rubber or something
Old Oct 15, 2009 | 02:25 PM
Arcitekt's Avatar
MOB Mentality
that should give you a hint. just get down there and check it out. how low is the rear sitting?
Old Oct 15, 2009 | 02:27 PM
the passanger side seems lower, i got a guy who wants to trade me his 13' si rims for mine my rims are pcws any idea what their worth or if the trade is worth it?
Old Oct 15, 2009 | 03:06 PM
98civdx's Avatar
Master Detailer
is your car lowerd?
Old Oct 15, 2009 | 03:18 PM
Not that I know of
tyronne1126
Honda Civic (2006 - 2015)
23
Mar 30, 2009 12:58 AM
Bigg G
Aug 31, 2008 03:29 PM
The-Kid
May 31, 2007 01:07 PM
CivicEX96
Mar 16, 2005 05:09 PM
