walboro 255 pump
Old Oct 14, 2009 | 10:12 PM
j0keefe21's Avatar
Default walboro 255 pump
how rich will my car run if i put in the 255 pump on a untuned ecu. i know the fuel pressure is going to go up but i plan on running nitrous so i beefed up the pump. just curious if anyone has run into problems with it being too rich.
Old Oct 14, 2009 | 10:15 PM
xxstuntin4life's Avatar
Default Re: walboro 255 pump
im not to sure about how rich it will run.. everytime ive used one i was already on a base map on hondata.. BUT remember do NOT NOT NOT let ur car go below 1/4 tank once u get one!
Old Oct 14, 2009 | 10:26 PM
raidacaipo's Avatar
dont get it if you dont have an adjustable fuel pressure regulator
Old Oct 15, 2009 | 03:21 AM
PJ B20ztec's Avatar
New User
Why can't you go below 1/4 tank?
Old Oct 15, 2009 | 06:35 AM
j0keefe21's Avatar
yea i read that too. i hear it sucks up too much air and it makes your car bog out. i'll just snag a fpr. the nitrous motor wont be done for a little anyways. i was just thinking about throwing that in now so i dont have as much work later. its just sittin in the garage anyways.
Old Oct 15, 2009 | 07:15 AM
1LowSol's Avatar
I installed mine about a month before i put my turbo on and before i got a base map. Ran fine but you could really smell the gas. Not to sure in the difference in Gas Mileage tho.
Old Oct 15, 2009 | 07:16 AM
j.packsb's Avatar
u cant get b elow a 1/4 tank whenever u have a bigger furl pump.. is this anytime u upgrade fuel pumps or jus when ur untuned?
Old Oct 15, 2009 | 07:19 AM
8VEYBEYB's Avatar
same question ^ bout to put a 255 on my DIZZM
Old Oct 15, 2009 | 07:23 AM
1LowSol's Avatar
I'm gonna say anytime, The fuel pump is doing it's same duty cycle weather tuned or not.. Maybe a lil more once you get a tune tho. Honestly i've been on E before in my car.. Never felt it bogging.
j.packsb's Avatar
yea im workin on boosting my d16y8 an my fuel pump came in today. i was gonna put it in now to save less work down the road but not if i cant go below a 1/4 tank... times are rough lol
Old Oct 15, 2009 | 11:45 AM
im not sure about other fuel pumps but i know that the walbros heat up a lot.. there in take pumps and if u go below a 1/4 tank they start to get hot and the burn up really fast.. the gas actually cools down the fuel pump..
Old Oct 15, 2009 | 11:49 AM
MHDesigns's Avatar
My walboro 255 put out 44psi at the FPR when adjusted as low as possible. Originally I could turn the fuel pressure(on OEM fuel pump) down to 32psi.I'm pretty sure that a better fpr would help tone it down though, I just haven't changed mine cuzz it runs great at 44-48.
Old Oct 15, 2009 | 12:06 PM
wat FPR are u running?
Old Oct 15, 2009 | 12:10 PM
MHDesigns's Avatar
RS Machine. It's one of the ones that has you cut the oem fpr in half, and re-use the bottom for mounting.
Old Oct 15, 2009 | 12:25 PM
o0o ok.. my car was on hondata s300 and i didnt have a FPR now im un tuned with a B&M FPR pretty much the same thing as urs.. i had to cut my stock regulator and put this one on.. im thinkin about getting a walbro 255 but i think i wana wait untill i get hondata again and get her tuned
SPOOLINmatt
Oct 25, 2012 08:55 AM
JDM_SOHC
Dec 15, 2007 10:20 PM
dome
Sep 25, 2007 02:50 PM
W.Zero
Dec 12, 2002 03:08 PM
Andrew 825SM
Nov 17, 2002 01:42 AM
