Car won't stay running.....
Finally got the car to start up last night and tonight, but will only stay running when the throttle is all the way open, but still only runs around a grand maybe. I have zero throttle response. I will not infect you guys with my thoughts and I will listen to what you guys think the problem could be. All the information would be greatfuly appreciated.
I am running 450 dsm injectors and I have the resistor box hooked up and done correctly. Got a 2.5 bar map sensor on there. If you wanna know anything else just ask and I will let you know.
And now the diagnoses are given.....
Thanks
Thanks
Thanks
Thanks
2. Did you set the fuel trim? running rich bogs it down since you have 450cc's
3. Did you by any chance **** around with the TPS? or accidently adjusted in a way?
I'm running a B16 with just new OEM bearings in it. The ECU was already setup for a 2.5 bar map sensor. Fuel pressure is right around 40. We screwed all around with the fuel pressure. Ran it way lay and high and still did the same thing. I popped in my stock ECU from my 92 hatch (P06) and it hit 2 grand and shut off. (I think that was just because it was not set for the 2.5 map). I was going to try and wire the stock map back in and try that.
Anymore thoughts?
Thanks for all that information. I will try each one and see what happens.
Anymore thoughts?
Any thoughts. I am going to change the injectors and switch back to stock map sensor since I will only be running seven pounds. Hopefully this will solve the problem.
The only thing I do not have hooked up is the electronic boost control. This would not cause this crappy crappy idle/ not driveable problem would it?
street_ride14
Jun 22, 2010 07:56 PM
93c1sol
Sep 8, 2005 11:06 AM
