Moroso or OEM Honda Oil Pan?
Old Oct 14, 2009 | 07:06 PM
DA TeG 90's Avatar
Default Moroso or OEM Honda Oil Pan?
I have heard that the moroso tends to leak a lot and not sure if its just the people who I heard it from saying that although my tuner said OEM would be better, but I was curious to what you all think about the moroso and if I should get the OEM oil pan instead?
Old Oct 14, 2009 | 07:21 PM
digdug18's Avatar
Default Re: Moroso or OEM Honda Oil Pan?
moroso works great on track. So long as you clean the old gasket off, and use some of that blue gasket stuff when you use the new gasket, you wont have a problem. But if your not road racing the car, why would you even need a moroso oil pan. Stick with stock...
Old Oct 14, 2009 | 08:16 PM
Dueceification's Avatar
The Moroso pan holds a extra quart of oil compares to the stock pan. Some people have had problems with leaking but I never have had any problems with my car. You can save yourself some money by just sticking with a stock unit but if you want to have a extra quart then go with the moroso. It also comes with the oil return & oil temp bungs already welded on.
Old Oct 14, 2009 | 09:33 PM
jnv255's Avatar
i think my Moroso holds 9 quarts.it did leak at first, the bottom wasent perfectly flat, sanded it down, put a gasket on it and its fine now
Old Oct 15, 2009 | 07:34 AM
DA TeG 90's Avatar
No road racing, just track and some street fun. what would you guys suggest? I have to get a new oil pan as I just picked up a bare b18c1 block that I am bulding for next spring.
Old Oct 15, 2009 | 07:37 AM
TehGhett0P1mp's Avatar
I would just stick with the OEM, I have heard nothing but leaking isues with the Moroso pans. Why fix it if it aint broke?
Old Oct 15, 2009 | 07:58 AM
batboyvaj's Avatar
my moroso never leaked...
Old Oct 15, 2009 | 08:20 AM
NonovUrbizniz's Avatar
Loved
http://www.hondamarketplace.com/show....php?t=1848964
INSTALLATION NOTE for OIL PANS:
1)When installing plugs, sealant MUST be used, either tape or paste.
2)When installing gaket, sealant must NOT be used. It is installed DRY. Please make sure it is clean and dry. Best option is to replace gasket.
99% of leaks are a result of not following these procedures.
My pan is rusted out above the header so I'm just getting a moroso... for a new stock one plus welding all the bungs it'd cost about the same... if you're going budget just get a used pan and some of those bolt through fittings...
Can't really argue with increased capacity and pre fitted for drain back and oil temp.
Old Oct 15, 2009 | 09:21 AM
Turbo-LS's Avatar
Get the moroso street pan not the drag pan. the drag pan you will starve the engine for oil in corners and braking. Been there done that
Old Oct 15, 2009 | 10:40 AM
DA TeG 90's Avatar
There is one that lightning motorsports is selling which is who I would get it from. I just wanted your take on the pans. I am not on a budget. I think I will go with the Moroso Steel oil pan. Not sure if that is the street or drag?
Old Oct 15, 2009 | 12:18 PM
96 GSR-T's Avatar
I use the Moroso Steel Pan, its kinda heavy but I have never had a leaking issue with it... I am glad I bought it.
Old Oct 15, 2009 | 03:38 PM
Turbo-LS's Avatar
just be sure its not a drag pan, the drag pan is th eone that requires the moroso oil pickup and has the kick out on the back of the pan. No good for street driving IMO.
steel pan is good to go, no leaks ever when i had one on my drag car. I think the leaks are user error.
Romodavid15
Mar 16, 2010 08:16 AM
bopbop93030
Jul 20, 2009 08:41 AM
civic_jdm16
Jul 22, 2007 11:50 PM
racin jasin R
Jun 15, 2007 10:53 AM
htownteg
Jan 30, 2004 07:15 PM
