2001 Integra Radio pin-out
Old Oct 14, 2009 | 12:39 PM
thundernoodle's Avatar
Default 2001 Integra Radio pin-out
Im trying to put a radio from a 1998 Integra into my 01 ITR. I plug it in and the anti-theft light blinks but I get no power when I push the button. I have the code and what not but I think the problem may be with the harness. The harness is kinda hacked up and some wires are capped. Does anyone have a pin-out for the plug that I could use to re-wire the plug?
Old Oct 14, 2009 | 02:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: 2001 Integra Radio pin-out
http://www.installdr.com/Harnesses/HA-Wiring.pdf, your 01 ITR may or may not use same plug as the 98 HU, although you did say "I plug it in and the anti-theft light blinks", did you use a plug that came with the HU or one that was still in the 01 ITR,
What color are the wires that are "capped"? 94
Old Oct 15, 2009 | 07:29 AM
Hmm. I used the one from the ITR. The ones that are capped are; actually spilts off of some of the regular wires. At some point someone had a system in this car and I think they ran extra wires from certain OEM wires. All of the capped one go into a plug with another wire that comes out of the main harness.
Old Oct 15, 2009 | 08:02 AM
fcm's Avatar
fcm
Old Fart
Can you take a pix and post it?
I need to know what the wires that are capped and running from a plug are and what wire from the main harness is connected.
Could the plug be the stock radio plug still hanging by one of it's leads, [not used by last guy] what color is that one lead. does the plug look like either one of the ones in the link
Which plug is it, [plugged into the 01 HU] the first one, [1986-1997/98] or second one, [1997-1998 and newer] in the link I gave you?
The problem is that on some Integra the 1986-1997/98 plug/radio harness was used all the way to 2001 and on other Integra the change over was made in 1997/98.
As you can see in the link, most of the wiring is the same, [color-designation], be careful with the brown/white, power ant. and right rear speaker neg.(-) are the same color, your 01 HU plug, [if newer type] may have a red lead, your 98 Integra radio harness, [if older type] will not have the red lead, red is illumination ground from "Dash Lights Brightness Controller" neither the illumination power, red/black or ground, [red] are shown on the wire guide in link. 94
JHP
13
Mar 9, 2009 12:20 PM
CRwreckz
Jan 4, 2008 07:17 PM
93civicexthug
Mar 23, 2007 02:20 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
Jonathan_ED3
Jun 21, 2003 04:16 PM
