Oil Light Comes on
Old Oct 13, 2009 | 08:35 PM
NteGSR2o9's Avatar
Default Oil Light Comes on
Old Oct 13, 2009 | 08:46 PM
Linked's Avatar
Default Re: Oil Light Comes on
do you have a leak? check for any wetspots on the block.
Old Oct 13, 2009 | 08:50 PM
egsleepercivic's Avatar
add oil the light will go off, your losing oil somewhere, most likely burning it
gl
Old Oct 13, 2009 | 08:53 PM
gwl's Avatar
gwl
Well, the dipstick won't measure if you are close 2 quarts low or somewhere around there. Did you measure how much is coming out the oil drain plug? Sounds like you are burning oil if you can't find any leaks, but that a lot oil and you should see some good size puddles. You can try some heavier weight oil to limit the amount oil if you are burning it up.
Old Oct 13, 2009 | 10:18 PM
NteGSR2o9's Avatar
Mikewallace
Aug 26, 2018 05:53 PM
itzyaboyzeem03
Jul 1, 2016 04:40 PM
IBriaIN
Feb 27, 2011 08:28 PM
Mr. Samurai
10
Feb 28, 2005 05:59 PM
Allstar
Oct 29, 2001 03:05 PM
