p30 pistons....
Old Oct 13, 2009 | 06:13 PM
Hondatech7713's Avatar
Default p30 pistons....
Ok I know this is a all motor question but I asked there and no one has a response., I want to run p30(99 SI) pistons in my ls-v. Now I seen a set on ebay from company called NPR anyone even use them????
Old Oct 13, 2009 | 07:03 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: p30 pistons....
P30 pistons come from the JDM spec 2nd gen B16A which yields .2 higher compression, so the in a B16A it would be 10.4:1 instead of 10.2:1 like all those found on usdm models
Not sure what compression would be on an LS vtec
Old Oct 13, 2009 | 10:32 PM
bryse68's Avatar
nope, but it yields about 11.5 compression ratio....
Old Oct 14, 2009 | 05:00 AM
dephtone's Avatar
11.8:1 with a b16 head and 12.1:1 with a GSR head.
This assuming you are using an OEM 3 layer headgasket.
http://www.c-speedracing.com/howto/c...c/compcalc.php
Plug in what you have, this will give you a pretty decent idea, depending on if you milled the head or not also.
People have used the NPR for ITR pistons, for a nice little NA b16 action.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/npr-pistons-piston-rings-2569157/ This thread has a few people that have used them. Hopefully you find what you are looking for.
civic-8442-
Jul 30, 2009 07:41 PM
stonet149
12
Nov 2, 2008 09:29 PM
ls_vtec_crx
Dec 17, 2003 03:01 PM
EFing8
10
Dec 14, 2002 04:00 PM
2latev8
Oct 27, 2001 11:29 PM
