Em1 Wont stop reving to redline after Intake manifold install
I just put on a JG edelbrock intake manifold on my car and now it wont stop reving like I have my foot stomped on the gas and theres no air leaks and it blowing black and grey smoke. Any suggestions its on a 99 civic si with a b16a2 non turbo
u have to have a serious vacuum leak..or your throttle body isnt on or somethin crazy like that..try startin it and put your hand on the throttle body opening to stop air flow and see if u can hear the monster vacuum leak
we blocked off the throttle body then it wouldnt even start at all. Then we let it have a lil air then it just redlined and tons of black smoke
r u sure the throttle body butterflys are closed cuz it doesnt seem like they are...u might have tightened the throttle body cable too tight..other than that did u replace the intake manifold gasket and/or the throttle body gasket..and/or make sure the injector gaskets are fine.. check all vacuum lines..because after market IM sometimes have some ports in weird spots..n it also sounds like maybe the main brake booster vacuum isnt hooked up
As others have mentioned, you have a big air leak somewhere.
Now my question....why would you change out the stock P30 manifold on your B16? You'd be hard pressed to get "any" extra hp at all on the motor in N/A form.
Same thing happened after i installed hondata gasket.
Simply stated, i didnt tighten the bolts tight enough
I only gave each bolt about 3 or 4 turns each ( on top of what i initially tghtened it to) and sure enough it was my problem
SSGojeta
Dec 27, 2008 09:29 AM
Duck Sauce
Nov 28, 2001 08:47 AM
