Need help with harness!!!!!!!!!
Old Oct 13, 2009 | 01:31 PM
94h22acord's Avatar
Default Need help with harness!!!!!!!!!
Ok guys, i have a 94 accord lx coupe with a jdm h22a swap. i recently got myself into a full motor build and started to tuck some wires. well, i pulled the fuse box inside under the dash and now i have one plug that i cant seem to figure out where it went. it branches off the fuse box plugs and is only 2 prongs...here are the pics. any help is extremellllyyyy appreciated thanks.
Old Oct 13, 2009 | 01:55 PM
HonBeer's Avatar
Default Re: Need help with harness!!!!!!!!!
Common amateur mistake by not tagging wires
Old Oct 13, 2009 | 03:03 PM
94h22acord's Avatar
um...thanks for the help? dick
Old Oct 13, 2009 | 03:10 PM
Bwill9886's Avatar
I'm sure he realizes that now. Maybe offer a suggestion with your criticism next time?
I unfortunately have not seen that part of the harness for this swap, but I remember hearing some of the JDM harnesses for the fuse box are not necessary.
Again, NOT SURE (so don't go cutting it off yet!), but its an idea. I couldn't find that plug in a quick search so I got nothing else.
Anyone else have insight?
Old Oct 13, 2009 | 03:18 PM
94h22acord's Avatar
thanks for the help. the only thing that scares me is that its dirty like the others that used to be in the engine bay...u checked it in a manual? or a schematic?
Old Oct 13, 2009 | 03:42 PM
jdmwannabee's Avatar
what color are the wires going to that plug?
Old Oct 13, 2009 | 04:13 PM
GhostAccord's Avatar
x2 on the wire colours. Not 100% without wire colours, but if they are BLK/WHT & BLK/YEL it is one of the distributor connectors.
Old Oct 13, 2009 | 04:23 PM
94h22acord's Avatar
i will run out and go check now
Old Oct 13, 2009 | 04:35 PM
94h22acord's Avatar
ok, theres a black with yellow stripe, and a black with white stripe
Old Oct 13, 2009 | 05:01 PM
94h22acord's Avatar
urgency bump...tryin to get this car runnin by the weekend
Old Oct 13, 2009 | 06:02 PM
TheMuffinMan's Avatar
He knows where you live!
Did you read Ghost's post?
It's a dizzy connection
Old Oct 13, 2009 | 07:06 PM
94h22acord's Avatar
Its on the chassis harness though, not the engine harness...is it still a dizzy connection?
Old Oct 13, 2009 | 07:34 PM
So it's coming from the Cabin harness assembly into the engine harness where the fuse box is?
http://www.hondaautomotiveparts.com/...5=WIRE+HARNESS
I'm looking at that....
Old Oct 14, 2009 | 02:11 AM
I'm guessing that you must have already chopped up your engine harness without labeling anything. That's gotta hurt the brain trying to figure this crap out eh!.
Here is where I think that those two thick wires would end up.
BLK/YEL = Ignition coil
BLK/WHT = Starter solenoid
Note: You should always get yourself a complete wire diagram for your chassis before you start a wire tuck or any wiring job for that matter.
Old Oct 14, 2009 | 05:23 AM
94h22acord's Avatar
yes its coming from the cabin harness...if u look at the picks i took u will see me holding the fusebox plugs and branched off of that same harness the two prong plug comes off of that
Old Oct 14, 2009 | 05:28 AM
94h22acord's Avatar
Not too bad actually. I only chopped the driver side cabin harness in the engine bay to come inside the firewall across the dash and to the other side so i can have everything in one spot and low behind the motor so u wont see it.
The plug that im askin about was never chopped its just one i cant find the other end to, it could be the dizzy i will check when i get off work. It actually might be obvious when i put the motor back in but i couldnt find the other end on the engine harness so i figured i would ask before i get stuck when the engine is in and in the way.
Old Oct 14, 2009 | 10:18 AM
94h22acord's Avatar
bump...for anyone who can confirm that the 2-p distributor connection is on the cabin harness of an accord?
Old Oct 14, 2009 | 04:23 PM
94h22acord's Avatar
just got home and squared it away found the other end of the plug...thanks for the help everyone
hotaccord243
Mar 19, 2010 06:17 AM
tienzien
May 21, 2007 03:48 PM
Zaakro
Dec 30, 2006 10:54 AM
jdmcuban
May 29, 2006 05:11 PM
X-MOB03
Oct 12, 2004 11:35 AM
