Whistleing noise?
Old Oct 12, 2009 | 03:39 PM
Arith7's Avatar
Default Whistleing noise?
Hey guys i have a 2000 Em1 and i have been hearing a whistle/scratching noise from my car.....it only happens from 2-4k rpms, moving or not. Anyone know what this could be?
Old Oct 12, 2009 | 06:37 PM
joelmatt89's Avatar
Default Re: Whistleing noise?
it's your intake, especally if you have a short ram intake and high flow filter the noise is amplified
Old Oct 12, 2009 | 06:51 PM
93egSLEEPER's Avatar
pop the hood, rev the motor from the TB and listen for it. i would bet its your intake as well.
Old Oct 12, 2009 | 06:59 PM
ej1love's Avatar
x2 for intake
Old Oct 12, 2009 | 07:03 PM
thumper64's Avatar
Rick Rabies is stuck under your hood, and he's making turbo noises. That scratching is him trying to get out.
Old Oct 12, 2009 | 07:04 PM
ej1love's Avatar
lol
Old Oct 12, 2009 | 07:11 PM
Arith7's Avatar
I just put on a full cai and this noise was happening before I put this on....
Its almost like a screeching noise I think its coming from a belt I really don't know
this noise is not consistent.....
Old Oct 12, 2009 | 07:15 PM
souds like possible the alternator or power steering belt then. is it when its cold more then hot?
Old Oct 12, 2009 | 07:16 PM
ej1love's Avatar
well, my intake only makes noticable noise on startup really.
Old Oct 12, 2009 | 07:29 PM
Arith7's Avatar
its both hot and cold
Old Oct 13, 2009 | 05:18 AM
joelmatt89's Avatar
If it's the belts slipping you can tighten them. Also they make a belt conditioner that reduces squeaking. You just spray it on the belt while the car is running it works great.
Old Oct 13, 2009 | 06:28 AM
Arith7's Avatar
How do I tighten them?
Whats the name of this spray?
Thanks for the help.
Old Oct 13, 2009 | 08:12 AM
joelmatt89's Avatar
go to any auto store and ask for belt conditioner. Something like this http://www.jcwhitney.com/jcwhitney/p...9&zmap=16544G#
To tighten them there is a tensioner bolt on them. I don't know how to explain it usually i just kinda loosen things up until i see which bolt is holding the tension and then go from there. It's pretty easy to figure out once you start looking at it. It is most likely the alternator, power steering would be noticeable because it would do it mostly when turning especially at slow speeds and I doubt your using ac right.
Old Oct 13, 2009 | 02:19 PM
Arith7's Avatar
I went to the auto store...
I was told it might be my water pump.
No I am not using my a/c I live in WI hehe.
Old Oct 13, 2009 | 02:28 PM
Simkin314's Avatar
I never trust auto store clerks anymore. Have been f-over too many times to trust them. I would not use belt conditioner sprays, but I would re-tension them. Buy a manual for your car if you haven't already, they do help a lot.
Depending on how many miles are on the car when the last time it was that the water pump and timing belt was replaced, determines if I would switch those out.
Most of the time, the belts either have an idler pulley (an extra pulley wheel that pushes against the belt to tension it), or are tensioned via being pulled taught by the driven device (such as the alternator being on a pivot joint). Either way, its fairly simple to figure out how to tension the belts, just give a quick look over.
Old Oct 13, 2009 | 02:35 PM
Arith7's Avatar
I went to high school with the guy I talked to...and he knows Honda's pretty well.
I haven't had the car long enough to know if the timing belt was replaced. The car has 110k on it, If it gets worse I will get them replaced, but i will tighten the belts first.
Thanks a lot everyone.
Old Oct 13, 2009 | 03:10 PM
r22thomas's Avatar
mine makes a whine type noise at 2300-2350. Ive always just overlooked it.
Old Oct 13, 2009 | 03:12 PM
Simkin314's Avatar
At 110K, if the timing belt and water pump haven't been changed, they really should be.
xandrake
Feb 7, 2007 08:12 AM
japmarket1
Oct 15, 2005 12:32 PM
unltdacc12
Apr 4, 2003 07:54 AM
pentaq
Jan 20, 2003 06:37 PM
