F/S 11sec all motor part out,legit b20block,4.7 HMO type-R tranz,Real RmF Headers
Old Oct 12, 2009 | 02:11 PM
KrazyLuEg8's Avatar
Icon7 F/S 11sec all motor part out,legit b20block,4.7 HMO type-R tranz,Real RmF Headers
wats good, Please bump if view'd and ill do the same will only take 5 seconds of your life lol..besides the other 12hrs ya sit reading **** lol..im pating out my 11 sec swap..i have time slips to prove it.selling a legit(papers) 97 fully built b20 block, has no more than 800-1000 miles..was properly broken in..only saw dyno and track..was neva driven on the streets,(which this setup could be daily'd with no problem with the proper tune)..all machine work was done by Bob's Speed Shop in Harrison.Motor made 230hp/160 torque with a b16 head and skunk 2 pro 2's..tuned by Cunha clm motorsports ..there is nothing absolutely wrong with it..goin diff route..will have vins and block numbers(could b seen in one picture) as soon as i get a chance. i could be forgettin details but feel free to ask me anything and dont be afraid to make an offer
Located Union City,nj 07087
~specs..Block..
84.5 mm,decked,hot tanked,cleaned in and out
12.5 Cp light weight pistons
Golden eagle rods
Acl race bearings, whole bottom end
89mm new ls crank
Gates timing belt
New timing tensioner
Unorthodox racing crank pulley
ls water pump
Shimmed Type-r oil pump
obd 1 alternator
oem oilpan
all gaskets are from honda dealer
ill also include the head gasket which is still fresh,but i personally would change it..
I spent a lil over 2500 on this i have receipts for everything .. askn 1500 obo..worth every penny
~head..all work was done my M&G machine shop..head is stamped as proof
(head is perfect..u could check it with a thinnest filler gauge and u won't see any warp'd areas at all..neva overheated at all, if it overheats the stamp will fall off) i got the head from a friend of mine, had it on a 10sec bubble..he works with HIBoost
2000 b16 head
ported & polished
5 angle valve job
Skunk 2 oversized valves
Skunk 2 dual valve springs
Skunk 2 titanium retainers
Ferrea bronze valve guides
type r valve cover
JB Polished Edelbrok intake manifold w/ 68mm throttle body,manifold is port matched to the head....1000 obo
will post piks
~98 HMO stamped Hydraulic Type r trans lsd with starter,axels and type r linkage
originally came wit a 4.4 final drive.
has no more than 250 miles since all the new parts installed
trans was built right.
carbon coated synchros from gearspeedinc.com
Mfactory 4.7 final drive w/ extended 1st gear....1500 obo
will post piks and numbers
number.. S80-3066324
~most recent pik..i painted it it black and polished the border
~you could still see in the pik the lsd mark on the trans b4 i painted it
~Latest Version Rmf headers already heat wrapped...Sold....
~ BNIB latest version of weisco lightweight pistons
custom 84.5 mm 13;5:1 compression pistons with brand new rings.. Still in box..500 firm
~MSD digital 6 box, ob2 gsr dizzy wit the msd distributor cap, msd external coil(the new model not the shity old style canister), and ill include the button for the 2step.. 275 obo
~Rc 440 obd1 injectors..Sold~
New Bseries Skunk 2 pro3's with Endyne Cam gears,(neva had the chance to intall)... SOld!!!!!!!!
Tato Built
Old Oct 12, 2009 | 04:36 PM
jdmhonda560's Avatar
Default Re: F/S 11sec all motor part out,legit b20block,4.7 HMO type-R tranz,Real RmF Headers
bump!!!!!
Old Oct 12, 2009 | 08:38 PM
KrazyLuEg8's Avatar
good looks for the bump!!!
Old Oct 13, 2009 | 12:51 PM
BradtheMachine_Si's Avatar
bump for you
Old Oct 13, 2009 | 03:31 PM
2001B18C1GS-R's Avatar
how mcuh fro just the pro2 cams and also whats the difference between a type-r oil pump and your shimmined itr pump
Old Oct 13, 2009 | 09:17 PM
KrazyLuEg8's Avatar
the pro 2's i sold to get the pro 3's and i just sold those..the pump puts out more oil pressure ..this will keep everything lubricated at high rpms..thats the reason y people spin bearing..lack of oil..normal oil pressure is 60-80 psi..mines was always at 80-100
Old Oct 14, 2009 | 03:37 AM
eddietech875's Avatar
New User
bump clean motor how much are you wanting for the block?
Old Oct 14, 2009 | 04:20 AM
KrazyLuEg8's Avatar
1500 obo negotiable
Old Oct 14, 2009 | 07:38 PM
KrazyLuEg8's Avatar
Cain Marko came threw and got the headers no problem at all..well a minor issue but it was worked out..bump for a good buyer..thanks
Old Oct 15, 2009 | 12:37 PM
KrazyLuEg8's Avatar
bump t tt
Old Oct 15, 2009 | 05:44 PM
illack91's Avatar
What kind of numbers did u put down?
Old Oct 15, 2009 | 06:08 PM
EgMadness420's Avatar
bump.. nice setup, wish i had the loot!
Old Oct 15, 2009 | 06:25 PM
Cain Marko's Avatar
Rotary Lift Specialist
Haha a slight scare but it's already fixed making the test pipe Saturday and it'll be on and helpin it scream bump for a good seller
Old Oct 15, 2009 | 08:52 PM
KrazyLuEg8's Avatar
ight..thats wassup my dude..good looks..enjoy them cuz i did lol
Old Oct 18, 2009 | 12:57 PM
KrazyLuEg8's Avatar
bump to the top
Old Oct 20, 2009 | 07:30 PM
KrazyLuEg8's Avatar
bump t
Old Oct 22, 2009 | 09:01 PM
KrazyLuEg8's Avatar
bumppppppppppp
Old Oct 25, 2009 | 09:21 PM
KrazyLuEg8's Avatar
bumpppp
KrazyLuEg8
Northeast (Sales)
Oct 26, 2009 01:32 AM
uleiro
Apr 21, 2008 11:07 AM
alloutmotor
Sep 2, 2006 03:15 PM
B16Civic93
Oct 22, 2004 01:50 AM
Jeff C
Dec 12, 2002 09:28 AM
