Lighting HID/Xenon kits, Retrofits and Associated Topics
92 EG 4 door taillights
Old Oct 12, 2009 | 01:51 PM
ULaughNow's Avatar
Default 92 EG 4 door taillights
aiight this is probably a easy fix....but here it goes
so i get a new battery and all that.....and for some reason now my taillights dont work.....my brake lights work but my taillights dont......everything else works in the car...even the fuse is showing its good....i've checked all the fuses and replaced the bad...and also checked the bulbs and they are good as well...not sure what the problem would be at all....
any ideas or helpful tips would be greatly appreciated
Old Oct 12, 2009 | 05:17 PM
EG9_808's Avatar
Default Re: 92 EG 4 door taillights
Check for wire connections?
Old Oct 17, 2009 | 10:15 PM
cr8ter's Avatar
head light switch maybe?...check for power and ground at the tail light...if no power i would pull the headlight switch out and do an ohms check on the switch
denniscariot
Jul 29, 2013 06:12 AM
Gogetta05
15
May 1, 2012 05:52 PM
mister.wong
Jan 27, 2008 12:41 AM
nefrideum
Jan 18, 2008 12:59 AM
kelliehager
Jan 14, 2006 07:23 PM
