fogs won't work on my EG
my eg's fog was working fine until one fine day it just didn't work. checked all the fuse and also checked the bulb in the fog. anything else that i should check? and also the fog switch always produce a clicking sound whenever i switch the fog on. just that it doesn't light up. any idea guys?
Check the grounds.
Get a screwdriver and scratch off the paint/primer to wherever you're grounding the wire to.
My fogs didn't light up due to it not touching metal l0l, but touching the primer. :x
Well obviously its not getting power, so go buy yourself a fuse tester and check where you spliced the wire to give it power and see if its still getting power, if so, go and search all the grounds / spliced wires to see if anything came apart.
raidacaipo
03-11-2009 11:40 AM
