quick wiring (wire tuck) question
Old Oct 12, 2009 | 11:30 AM
neilae86's Avatar
Default quick wiring (wire tuck) question
sorry if this is in the incorrect setion but i just joined and couldnt find anywhere else to put it.
Basially im planning a wire tuck and want to know is there any wires i should avoid cutting? i heard a small resistane drop happens over the soldered joints. Would this be a problem with the likes of wires running to sensors or injetors etc
cheers
Old Oct 12, 2009 | 11:44 AM
seanbev24's Avatar
Default Re: quick wiring (wire tuck) question
988 page thread, everything you'd ever want to know about wire tucks...
https://honda-tech.com/forums/showth...=shaved+tucked
I have no problems with my extended injector wires I just made it so the harness goes under the manifold.
Old Oct 13, 2009 | 02:24 AM
neilae86's Avatar
cheers for the link but ive searched through that thread a few times now and still can not find a deffinate answer, some people say yes others say no?
Old Oct 13, 2009 | 06:16 AM
fcm's Avatar
fcm
Old Fart
Any connection has resistance, adding length to a lead adds resistance, a proper connection will have the least amount of resistance, as will the least amount of connections.
The best possible way to extend leads is to replace the whole lead, [no connections] very time consuming as you are making a new harness, next would be to replace the whole lead from the extension point, [one connection], also time consuming but a better cleaner way.
What we will do is hit up the pick&pull for a complete harness, cutting the leads needed back up the harness far enough to make up the extension and then making the connections, [one for each lead].
Best way to make a connection is to strip 1/2" of insulation from leads, push leads, [stripped parts] together, use a strand of copper wire from a scrap piece of lead, to wrap around the leads that have been pushed together, making a tight bundle, solder the connection, "paint on" some liquid electrical tape, slip heat shrink over connection and shrink it, makes pretty much a bulletproof connection with the least amount of resistance and airtight so oxidation can not occur. 94
Coopa B18c5
Apr 29, 2013 10:37 AM
em2ssm02
Audio / Security / Video
Aug 18, 2008 05:04 PM
thinkbrianthink
Mar 6, 2003 08:52 AM
