cable reel 01 EX accord
Old Oct 12, 2009 | 03:23 AM
hondamark35's Avatar
Icon2 cable reel 01 EX accord
story: i replaced the cable reel behind the steering wheel over a year ago when all of the controls on the wheel quit working. that fixed it, everything worked fine until recently...
issue: cruise, radio controls and the horn no longer work. haynes manual has no wire diagram for the horn. (lowsy garbage..) i've tested for continuity on each wire in and out of the reel, i get nothing..
question: what is the procedure to narrow it down to the $100 reel needing to be replaced? which wires (colors) are on the horn circuit? shouldn't i have continuity through the reel at all times? does anyone have a horn wiring diagram?
Old Oct 12, 2009 | 07:25 AM
redbull-1's Avatar
Default Re: cable reel 01 EX accord
This link has the diagram:
http://ww2.justanswer.com/uploads/lo..._schematic.pdf
Also check the horn relay in your under hood fuse/relay box.
Old Oct 12, 2009 | 08:18 AM
thanks for the link. that helps
yeah, i didn't mention it but i had already checked the horn relay and it was fine.
Jeaton80
Mar 11, 2015 02:52 AM
zue1nia
10
Jul 6, 2013 11:06 AM
RED_90TEG
16
Apr 19, 2007 07:33 AM
stocker2shocker91
Aug 3, 2006 01:30 PM
AWDxBOOST
Mar 19, 2004 01:45 PM
