All motor b18b
Old Oct 11, 2009 | 06:34 PM
brandonb18's Avatar
Default All motor b18b
well im in the process of building my b18b engine all motor, i get high compression pistons and rings, and im getting good cams,
any suggestions for what cams to get for a quick vtec killer?
and what else could i do to run an all motor car besides pistons and cams?
thanks.
Old Oct 11, 2009 | 06:39 PM
93egSLEEPER's Avatar
Default Re: All motor b18b
are you running a vtec head? you will need to build your head for aftermarket cams as well. look into intake manifolds, a good header, port and polished head, port matched TB and IM, there are tons of things. whats your budget?
Old Oct 11, 2009 | 06:41 PM
brandonb18's Avatar
i have the engine put together, i am just adding stuff.
im just really looking for what kind of cams i should get.
my budget is like 400 for cams
Old Oct 11, 2009 | 06:46 PM
brandonb18's Avatar
and no, non vtec bro.
Old Oct 11, 2009 | 07:03 PM
400 for cams? hmm hard to find. look into some blox cams or hit up the marketplace and try to find a set of used ones with cams gears. you will want them. you will built the head with springs retainers and all that correct?
Old Oct 11, 2009 | 07:06 PM
brandonb18's Avatar
yeah thats correct
Old Oct 11, 2009 | 07:08 PM
im a big fan of the blox cams for the price. what compression are you running? i would get the blox b's or c's
Old Oct 11, 2009 | 07:10 PM
Jimster480's Avatar
Built LS's dont make power like LS/VTEC. Why not just go LS/VTEC?
Old Oct 11, 2009 | 07:14 PM
i wagoing to make the s but he sees pretty set on the all ls build... seems kinda wasteful to me
Old Oct 11, 2009 | 07:36 PM
Jimster480's Avatar
yea building non vtec motors is pretty pointless. The VTEC heads just flow alot better than the NON-VTEC ones, and they make alot better power...
Old Oct 11, 2009 | 07:50 PM
vtec= more air and more fuel which = power. if non vtec motors were capable of being fast w/o FI, then swaps would be way cheaper and easier to come by. also less cars would be stolen. haha
Old Oct 11, 2009 | 07:52 PM
Jimster480's Avatar
true dat
Old Oct 11, 2009 | 11:12 PM
fastrxu's Avatar
You gotta get ti retainers and dual springs might as well do flat valves and you still gotta tune it.
And you'll lose your street driveability if uou go to wild o' cams
Go lsv
Old Oct 11, 2009 | 11:49 PM
MilanoEj1's Avatar
instead of going lsv, get a gs-r. good luck on your build though.
Old Oct 12, 2009 | 05:20 AM
Jimster480's Avatar
that would be dumb. Considering that LSV makes more power than a GSR.
Old Oct 12, 2009 | 06:00 AM
Skip01's Avatar
F all the comments here.
Go LS All Motor, everyone has vtec , that's all they know.
Soooo much more respect too go against the grain , they've had a few 200hp LS builds on here.
Old Oct 12, 2009 | 06:05 AM
Jimster480's Avatar
yea I understand wanting to be different, trust me. I have a Built D on boost, not that many people actually go that route. But the thing is that a fully built LS might make 200HP, but is that going to be streetable? You are going to need some very heavy cams to make that power. Therefore its going to idle like a race car and get no gas mileage. There was a reason that Honda made VTEC. Purposely not using it is a little bit like slapping the engineers in the face. And it really wont be a VTEC killer regardless, i mean fully built you would be able to take stock B16's and GSR's. But any mildly built LS/VTEC or B20/VTEC will eat you.
Old Oct 12, 2009 | 06:36 AM
vtechjunkie's Avatar
I heard somewhere that if you plan on building the head, then vtec doesn't make too much of a difference. OP, get some more money into your cams. They are crucial for all motor builds. I have a buddy that bought some Bisimoto cams and he made great power all the way to 11,500 rpm. His tuner didn't want to go past that with his flow charts being the way they were. He was running boost too though. Great cams!
Old Oct 12, 2009 | 06:44 AM
Jimster480's Avatar
ofc VTEC makes a difference. Because you can make cams for low end power or high end power. VTEC allows you to make cams for both. If you make all your power up high then you wont make anything down low. And if you make it all down low, well you get the idea.
Old Oct 12, 2009 | 06:48 AM
fastrxu's Avatar
Are you sure stock for stock, the lsv makes more power????
Althougj gsr would be ideal, we're talking about working with what you already have so... If uou really wanna go allmotor go for it.
But like someone else also postes your gonna lose street driveability just to beat mild gsrs
Ie really rough idle, low gas mileage, you probably wont run pump gas
Old Oct 12, 2009 | 06:51 AM
It's something that I read on here, in one of the all motor section.
Old Oct 12, 2009 | 08:00 AM
Jimster480's Avatar
well considering that a built VTEC head doesnt cost $3000, yes its very dumb. Stock for stock LSV makes about the same power as a GSR and it has more TQ. Now building it makes it make even more power and it still costs less.
Old Oct 12, 2009 | 11:47 AM
wrestler72's Avatar
check this out...amkes me want to go out an get an LS
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/205-whp-ls-graph-inside-pump-gas-93-oct-2176287/
Old Oct 12, 2009 | 12:09 PM
Jimster480's Avatar
ya but that is FULLY BUILT and hes going to get what GAS MILEAGE?
Old Oct 13, 2009 | 07:06 AM
wrestler72's Avatar
i wouldnt say fully built, built yes but i dont think its anything too crazy
