94 VX Hatch DF grinding HARD :ugh:
Old Oct 11, 2009 | 04:15 PM
123HondaFan's Avatar
Default 94 VX Hatch DF grinding HARD :ugh:
when im driving (at any speed) the drivers side front tire grinds like a have a brick wedged between it and the fender and i took the tire off to see it the brakes we stuck and the rotor and lugs will rock back and forth and i can see the axles moving a little but also. the caliper doesnt move and none of the other parts move either..... wheel bearing? axle? flux capicitor? maybe its the do-hickey haha idk but and help would well help
Old Oct 11, 2009 | 04:17 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: 94 VX Hatch DF grinding HARD :ugh:
Wheel bearing.
Old Oct 11, 2009 | 05:07 PM
o if its the wheel bearing how o i tget to it? ive looked and looked and cant find anything about it not even in the haynes manual wtf
Old Oct 11, 2009 | 05:09 PM
teamjdm239's Avatar
take the bottom control arm off the ball joint, pull the hub off the axle by spinning the assembly, and you should be able to get it out.
Old Oct 11, 2009 | 05:39 PM
sounds simple enough i suppose. am i going to need any special tools?
method520
Mar 15, 2010 09:08 AM
lowered94accord
Mar 16, 2007 10:24 PM
Slammed1993
Oct 16, 2006 08:19 PM
ironcheftony
Sep 15, 2003 07:45 PM
kilabeez
Sep 17, 2001 11:22 AM
