HID RETROFIT! D1S Projectors, ballasts, ignigtor and wiring! Same as E55!
These are out of wrecked 08 Jaguar XK. The D1S bulbs and projectors are the same used in the common e55 Mercedes retrofit.
2) OEM Hella Ballast's -12v 35w. 1100vDC/85vAC
2) OEM D1S projectors with shroud
1) D1S bulb, I dropped the other when taking them out.
All you need is 1 Bulb and they are good to go. Work perfectly!!
All the Wiring is complete and they will come with the full headlight harness and motor.
This is about a $300 setup if bought used plus another $50ish for the second bulb.
I am asking $150 shipped to your door
Jmsklmn
Nov 23, 2009 03:23 PM
