100 octane for emissions?
Old Aug 29, 2002 | 06:56 AM
spettinger's Avatar
Default 100 octane for emissions?
i am about to take the IL emissions test, i have run about a half a tank through my B16 with "guaranteed to pass" emissions cheater. they say to run the tank down almost empty, refill with premium like always, and take the test. a gas station near me sells 100 race gas. would it help to run higher octane gas? i am also going to disconnect my vtec solenoid with hopes of cleaner emissions in high rpms. i do have a stock exhaust on my car, stock cat, stock intake, you name it. drives like i am trying to go snorkeling with a straw. thanks
Old Aug 29, 2002 | 07:39 AM
EF_LSVtec's Avatar
Default Re: 100 octane for emissions? (wreckedhatch)
Tell you the truth, i did the same thing, put the guaranteed to pass and followed instructions to the note, refilled w/ supreme gas (91 octane), ran it hard before the test and still failed. When I finally passed 2 weeks later, I was running 87 octane, new plugs and new Catalytic. But this is California, I dont know what kind of restrictions or guidelines you should follow in your state.
Old Aug 30, 2002 | 10:58 AM
spettinger's Avatar
Default Re: 100 octane for emissions? (EF_LSVtec)
is your premium only 91?! we still have 93 in illinois. ouch.
Old Aug 30, 2002 | 11:10 AM
Malgerus's Avatar
94 in BC
Old Aug 30, 2002 | 11:13 AM
andrew dc's Avatar
Default Re: 100 octane for emissions? (89_Y_49)
you want to run a low octane gas for a complete burn.. and some iso heat or that guarnty to pass stuff.... new plugs, cap and rotor dont hurt either
Old Aug 30, 2002 | 11:55 AM
dumbchild's Avatar
Default Re: 100 octane for emissions? (CRX25)
put a liter of "methyl hydrate" in your tank when full. worked for me.
Old Aug 30, 2002 | 03:06 PM
90CIVICSI's Avatar
I failed emissions BAD in Canada 1990 Civic CX STOCK. I put a bottle of "Guaranteed To Pass" ( http://www.autobarn.net/ch05063.html ) with a full tank of 91 Octane, and ran it untill it was empty. The night before the test, I filled up, and added another bottle of "Guaranteed To Pass" , took the car for a good run on the way, and PASSED. I also removed my Air Filter before the test. Try that.
Good Luck
Old Aug 30, 2002 | 04:04 PM
86CRXSi's Avatar
Default Re: 100 octane for emissions? (90CIVICSI)
try this simple free solution, put piece of cardbord infront of rad before you get there , get your temp way up and you are guaranteed to pass. if your car is running hot it will burn everything out...............tried and true.
Old Aug 30, 2002 | 04:26 PM
Perfectionist's Avatar
Default Re: 100 octane for emissions? (86CRXSi)
Yes, but too hot and you fail because of high NOX readings.
EG2Driver
10
Sep 22, 2006 10:27 PM
DannyDeuce
Dec 21, 2005 11:39 AM
strsi
Apr 10, 2005 07:51 AM
AVXHATCH
Jul 6, 2003 09:12 AM
