Clutch chatter?
Old Oct 11, 2009 | 11:56 AM
Em1_coupe's Avatar
Default Clutch chatter?
ok wen ever i first get out of first gear if i let the rpm go under 1k i can feel something in my engine bay making a vibration that can be felt while i am inside of my car but if i keep the rpm above 1k while gettin out of first gear i can still feel the vibration noise but not as strong. And i can also feel a little vibrating when i switch from first gear to second gear and second gear to third but after third i dont feel any vibrations. Any advise will help i think it might b clutch chatter but in not 100% sure thanx for viewing,.
Old Oct 11, 2009 | 12:43 PM
Em1_coupe's Avatar
Default Re: Clutch chatter?
if this helps any my car is a 2000 honda civic si
Old Oct 11, 2009 | 02:35 PM
Emorales's Avatar
Aftermarket Clutch ?
Old Oct 12, 2009 | 09:20 PM
Em1_coupe's Avatar
nope stock clutch
Old Oct 13, 2009 | 07:45 PM
Em1_coupe's Avatar
ttt
Old Oct 13, 2009 | 08:01 PM
cleansi's Avatar
sounds like a bad motor mont you check them usually on my em1 its the rear or tourqe mounts
Old Oct 13, 2009 | 08:21 PM
rndmheroxx's Avatar
does it happen if your clutch is completely engauged but still under 1k rpms?
Old Oct 13, 2009 | 09:31 PM
Em1_coupe's Avatar
ya it only happens when i level out the clutch to get outta first gear
Old Oct 14, 2009 | 03:48 AM
R666_EK's Avatar
I'm betting its the motor mounts as well... Or maybe its your driving.
Old Oct 14, 2009 | 04:05 AM
madracer's Avatar
rear motor mount is bad.and also check the torque mounts
Old Oct 14, 2009 | 10:41 PM
Em1_coupe's Avatar
ttt ok thanx for the help guys keep the suggestions coming
Old Oct 14, 2009 | 10:59 PM
JdmOdz's Avatar
bumppp
Old Oct 15, 2009 | 08:43 AM
Em1_coupe's Avatar
ttt
Old Oct 15, 2009 | 11:49 AM
Em1_coupe's Avatar
ttt
Old Oct 15, 2009 | 03:02 PM
R666_EK's Avatar
Have you even tried the suggestions so far? If its NOT the mounts let us know.
There really aren't a whole lot of probable cause.
Old Oct 15, 2009 | 03:56 PM
westcoastjdm's Avatar
Check the release bearing.
Old Oct 15, 2009 | 09:03 PM
Em1_coupe's Avatar
ok i checked the three main mounts and i didnt c any rips or tears on any of them and for the torque mounts i replaced both of them a year ago
Old Oct 16, 2009 | 03:31 PM
Em1_coupe's Avatar
ttt
Old Oct 17, 2009 | 12:43 PM
Em1_coupe's Avatar
ttt
Old Oct 18, 2009 | 10:19 AM
Em1_coupe's Avatar
ttt
Old Oct 18, 2009 | 02:52 PM
Hybridvalve's Avatar
Clutch chatter would be more so felt with a jerking whilst maintaining a steady rpm not simlply a vibration .
You should jack the car up , prop it have someone engage the drive and run first gear
while listening for actual location of vibration could be something loose within the engine bay
Old Sep 26, 2023 | 08:52 AM
bogdah's Avatar
Hey guys, i know this is 14 years later, but for anyone having this issue, i was having the same thing. The car was jerking along with the shifter when releasing the clutch from 1st from a stop. I checked the battery and there was not enough current when idle and revving in 2k rpms (under 13V). When i looked at the alternator it was shooting sparks(not giving enough current). Luckily my issue was only a loose screw but check your batteries and alternators people
Old Oct 24, 2023 | 10:19 PM
Ricelord's Avatar
where was the lose screw? I have the same issue
will rockit
May 7, 2015 08:00 PM
beat
Transmission & Drivetrain
Jun 12, 2009 01:21 PM
1hgej1
Mar 30, 2009 09:55 AM
SoyMilk
53
Sep 14, 2007 11:32 AM
19cIvIc94
Apr 30, 2007 06:30 PM
