help ASAP, short circuit.
Old Oct 11, 2009 | 11:41 AM
haas480's Avatar
Default help ASAP, short circuit.
heres what happened:
engine swap in a 95 civic coupe dx.
accidently grounded the positve.
battery fried, blew backup fuse in engine bay box.
put in another battery, and it was half dead, so it would just click the starter.(fuel pump and all still working, just weakly)
switched to a new battery, and now the CEL and fuel pump don't come on when i turn the igntion on.
thus doesn't turn over either.
i check the grounds.
i checked fuses under the dash and in the bay.
nothing....
ECU fry? hah, or what.
help me out. thanks.
Old Oct 11, 2009 | 11:44 AM
Former User's Avatar
Default Re: help ASAP, short circuit.
Replace hood fuse 31 and dash fuses 24 and 18 with known good fuses.
Old Oct 11, 2009 | 11:45 AM
haas480's Avatar
thanks, ill do it right now
Old Oct 11, 2009 | 11:46 AM
Does the oil pressure light turn on with the key in ON(II)? If not, replace fuse 15 under the dash with a known good fuse.
Does the starter crank the engine?
Old Oct 11, 2009 | 11:51 AM
haas480's Avatar
yes, oil pressure light, and no cranking over. no starter life or fuel pump.
Old Oct 11, 2009 | 11:53 AM
Make sure the thermostat ground wire and the engine-to-transmission ground wire is clean and tight.
Old Oct 11, 2009 | 11:59 AM
haas480's Avatar
k. n where are these fuse #s. cuz all i know is which they are by readin the diagrams which just gives the name.
Old Oct 11, 2009 | 12:06 PM
Old Oct 11, 2009 | 12:11 PM
haas480's Avatar
excellent, thanks a million. i'll get right on this.
Old Oct 11, 2009 | 12:33 PM
haas480's Avatar
i got it. i forgot about the thermo ground. but i went thru cleaned um up and changed the fuses that all looked to be good. one or the other fixed it. thanks man, appreciate the help.
Old Oct 11, 2009 | 12:38 PM
i got it.
turbo93daa
18
Nov 4, 2009 11:55 AM
haas480
Oct 11, 2009 12:34 PM
nyjdmhatch
Mar 2, 2005 08:06 PM
Mr. Vapor
Jun 15, 2004 09:24 AM
Mr. Vapor
Audio / Security / Video
Jun 14, 2004 03:17 AM
