MINI ME CRX- Fuel cutout problem HELP????
Old Oct 11, 2009 | 11:36 AM
momoxsparco558's Avatar
Icon3 MINI ME CRX- Fuel cutout problem HELP????
OK so here is exactly what happens.
I get in the car and start it, it idles high (2000 rpm) For a while. It sounds fine. I wait for it to heat up, so the rpm will drop. Now, when it heats up and drops it does not idle evenly (jumping from 1000 to 25000). I know that alot of hondas have this problem when hoses are switched around. BUT that is not all. When i give it gas, it revs, then cuts out. It is suckin in air, but seems like its cutting out gas. Ideas?
(Note: p28 ecu NOT TUNED)
Old Oct 11, 2009 | 03:36 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: MINI ME CRX- Fuel cutout problem HELP????
Originally Posted by momoxsparco558
(jumping from 1,000 to 25,000 RPM)
Well I would have to say your motor is toast. Honda motors can't go up to 25,000 RPMs; you are screwed as it is not a typical Honda problem…
Check and clean the IACV...
Old Oct 11, 2009 | 03:55 PM
My bad "2500"
Tdelgado03
Jun 9, 2015 04:30 AM
RiTtEk401
Nov 28, 2011 12:43 PM
ranger91
Jun 28, 2008 02:39 PM
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
Boost2NA
Sep 10, 2002 02:33 AM
