D15Z1 died
Old Oct 10, 2009 | 10:04 PM
ludemach23's Avatar
Default D15Z1 died
Pullin out of the driveway and car just died.
checking everything over and no spark.
Any ideas? Dizzy? coil? ECU? wiring?
suggestions???
Old Oct 10, 2009 | 10:17 PM
MHDesigns's Avatar
Default Re: D15Z1 died
Just shut off or what? will it crank? More details?
Old Oct 11, 2009 | 09:35 AM
ludemach23's Avatar
cranks over
no spark. has power goin to dizzy and power to the coil
AAAAAAAAAAAAAHHHHHHHHHHHHHH frustrating
Old Oct 11, 2009 | 11:56 AM
MHDesigns's Avatar
Fuel? pump bad maybe?
Old Oct 11, 2009 | 12:07 PM
ludemach23's Avatar
changed coil and it fired up and ran for about 10 minutes now sounds like its down a hole but when i pull a wire it nearly dies.
so it has spark and is technicaly running but not well and it spudders almost like a blown headgasket but compression is good no smoke out exhaust and no loss of fluids at all!
If it not one thing its another
Old Oct 11, 2009 | 12:14 PM
Former User's Avatar
Any CEL codes? You might want to have the igniter unit tested. How do the plugs, wires, cap, and rotor look?
Have you checked the mechanical timing?
Old Oct 11, 2009 | 12:26 PM
ludemach23's Avatar
no codes plugs ok, cap and rotor new, wires a little haggered
havent checked timing yet
how would i check the ingniter?
Old Oct 11, 2009 | 12:30 PM
Consider replacing the old wires.
Take the igniter unit to an auto parts for testing. This is generally a free service.
Old Oct 11, 2009 | 12:32 PM
ludemach23's Avatar
yeah after i check timing, rule out everything else i'll get new plugs!
Old Oct 11, 2009 | 01:06 PM
ludemach23's Avatar
wires were bad. put a new set on and its smooth as silk now.
Old Oct 11, 2009 | 01:11 PM
RedEJTwo
May 9, 2015 01:11 PM
micah13x
11
Apr 14, 2011 03:09 PM
MugenHonda
Oct 2, 2005 01:28 PM
2k1_ITR_0736
17
Jan 26, 2003 04:09 PM
model x
Sep 13, 2002 12:51 PM
