Selling my turbo and b18c5 FULLY built turbo motor
Selling my turbo and b18c5 FULLY built turbo motor tuned at 15psi. This is a complete, modified, and ready to beat out most b18c5turbo setups in houston. except for DR. Joe. I spent thousands and thousands of dollars to built this motor, so please no lowballs. Receipts alone I spent 30K, but I know i spent over that when this motor was in my type R. YOU may have all the receipts and warranty's and etccc...All the parts were professionally installed, costumed, and new when purchased.
Engine was built around 25k original miles. I took out the turbo and motor when my car was at 32K miles, so the whole setup only has less than 10 thousand miles on it.
---These prices are not made up, I will give you all the documentation.
1. JE Forged 9:1 compression pistons w/ ring set(500.00)
2. Eagle Connecting Rod (330.00)
3. JG Edelbrock Type-R Racing Manifold (300.00)
4. JG Edelbrock Type -R Throttle Body (300.00)
5. Golden Eagle Sleeve (1000.00)
6. Greddy Extreme Timing Belt
7. AEM Engine Management System (1300.00$)
8. Exedy Racing 3-puck sprung hub clutch assembly (300.00)
9. RC 750cc injectors w/ OBD-1 clips (400.00)
10. GT35R Dual Ball Bearing .82 /r S-housing turbo (500.00)
11. syclone/typhoon wastegate controller
12. NGK Iridium X2 range colder spark plugs NEW!!!
13. Driveshaft Shop Stage 3 Axle with spindles and ARP lug studs (1000.00)
14. Edelbrock cam gears
15. Ferrea stainless steel valuves, 90 lb springs, titanium retainers, titanium retainer clips, valve locators.(1200.00)
1. F1444P – intake valves – competition plus turbo valves 1mm oversized
2. F1445P – exhaust valves – competition plus turbo valves 1 mm oversized
3. S10026 – Dual Spring – Turbo Special Alloy
4. E11000 – Titanium retainers
5. SL1000 – Spring Seat Locator
6. K10034 – Acura Radial Valve Locks
16. Hone Block, Deck Block
17. Ported and Polish Head
18. 12.5 lb ACT flywheel
19. Moroso Oil Pan
20. MSD Street Blaster Coil and also MSD starter kit (400.00)
21. 3.5 bar map sensor
22. Apex turbo timer
23. 3” Thermal Exhaust System
24. SideWinder V2 4” Downpipe
25. 44mm Polished Wastegate (346.00)
26. High Flow Racing Cat
27. Koyo Radiator (350.00)
28. AEM High Volume Fuel Rail
29. Custom Made Intercooler Piping (2.5” stainless steel) (750.00)
30. Purosil Hose Couplers
31. Prothane Motor Mount Insert Kit
32. Spoon Sports Thermostat!!!
33. RFL Blow Off Valve
34. Greddy Oil Catch Can
35. AC S7 Invision Gaguge – 2” Oil Pressure
36. Engine tuned by Payne Tech
37. Brand New Radiator Fan with FAL bracket.
38. Front wheel Stage 3 axles can withstand 500hp..(450.00$)
39. Oil Gages (Lean&rich,Oil temp)(175.00)
40. JDM Mugen Power oil cap bronze in color 90.00$ (BRAND NEW)
41.B series Gasket gears (150.00)
42.High Boost Spring for Blitz Blow off valve (100.00)
43. Apex-i VAFC 1 the Blue screen version. (100.)
44. Brand new TEK (169.00)
45. Custom piping for the turbo (1500.00)
I have way more that I havent listed, but they are all on the receipts. I did not part out anything from this built, so you dont have to worry about that.
-I will also include all the dyno results. This motor has not been raced or been to the track.
my asking price is high because I know how much I spent on this setup and I cannot afford to lose it all.
Asking price for everything- 9K OBO or trade for something thats worth 9K. Trust me you will not be disappointed with this setup.
19. Moroso Oil Pan
jimjam187
Mar 6, 2008 06:30 PM
*Boostwerks*
Jul 5, 2005 12:48 PM
