What is the torque spec for the IACV
Old Oct 10, 2009 | 02:07 PM
AtoZ's Avatar
Default What is the torque spec for the IACV
Subject vehicle: 95 Accord ex vtec
Anyone know the torque for the two bolts that hold the IACV in place? The iacv bolts on this engine have 12mm hex heads. I figure the diameter is around 8mm. I put them in and torqued them to 7 ft lbs. They seem to be rather long bolts for that little part, so I started at a lower torque. The part seems snugged up and on there secure. I forgot to measure the diameter of the bolt before asking this question, thinking I was going to find the spec in Helms, but couldnt find any spec listed. Generic torque value charts hint at 8 to 18 ft lbs. Not sure of the grade of the steel either, the head is marked something like this: | 00. The Throttle Body torque is 16 ft lbs for four studs/bolts, and I think they are about the same diameter. So, what do you guys think, 7 ok ?... 10 ? ... 12 ? ... 14 ? ... 16 ft lbs?
Old Oct 10, 2009 | 02:17 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: What is the torque spec for the IACV
7 ft. lbs. is correct. It is listed in the Helms manual.
Old Oct 11, 2009 | 07:55 AM
AtoZ's Avatar
Tech8, what page is it on, I wasnt able to locate it.
Old Oct 11, 2009 | 08:20 AM
GhostAccord's Avatar
The Honda shop manual shows 16 lbf-ft. It's located on page 9-2 of the CD chassis manual.
Honestly, I have never taken out the manual for tq specs on parts like this. I always use the gudentight rule when it comes too small stuff like this. As long as it seals and stays tight, all is good!
tech8's Avatar
Global Moderator
Loved
Community Favorite
My mistake, I was remembering the torque value for the FITV.
The IACV torque value should be 16 ft. lbs. Look at page 9-2.
Edit: GhostAccord beat beat to the post.
Old Oct 11, 2009 | 08:39 AM
AtoZ's Avatar
Ghost and Tech8,
Thank you. I swore I had seen it before, but when I wasnt able to find it listed in the 11-69 at seq area. I looked in the cooling system chapter too and the specs in the front of the manual. I think I'll snug it up a bit more just to be sure. 9-2 in my Helms has this as part of the intake manifold, which is only 3 pages.
Hunter
Feb 17, 2011 06:31 PM
Petrarca426
Feb 3, 2010 09:56 AM
JDMCRX
Jul 5, 2004 01:10 PM
anothersickhatch
12
Jun 10, 2004 02:26 PM
windg@t
Dec 2, 2003 03:48 AM
