Immobilizer Chip and ECU question
Old Oct 10, 2009 | 01:05 AM
Shwilson's Avatar
Default Immobilizer Chip and ECU question
Ok so i have a 2002 accord Lx w/ the F23a4 ULEV long story short i have 2 giant holes in the block and ill never use a CAI again. now to the point Im getting a a used JDM F23a and i am told that i will not be able to use the ECu because of the immobilizer. What im trying to find out is if there is a way to bypass to immobizer so i can use the JDM ECU without haveing to get a remote starter? my other question is if i cant use the JDM ECU will the ULEV ECU work with a non ULEV engine? The person im getting the new motor from says it will work but other people say it wont. if i could just get a definete on that thats my biggest concern with the swap.
Old Oct 10, 2009 | 02:22 AM
wesk18's Avatar
Default Re: Immobilizer Chip and ECU question
why not did the cai mest up ur engine??
Old Oct 10, 2009 | 03:01 AM
Shwilson's Avatar
I hit a big puddle that i didn't see and sucked up a whole lot of water and hydrolocked it so now theres 2 gaping holes in the block
Old Oct 10, 2009 | 08:20 AM
TheMuffinMan's Avatar
He knows where you live!
I'm unsure on the JDM F23a but I'm sure a chipped P28 with a F23 map on it would work. What state are you in? Doing a chipped ECU requires you down-convert to OBDI so you lose the OBDII scanning abilities from the port. If you need that for registration/inspection you'd be hosed.
Old Oct 11, 2009 | 05:14 AM
YeuEmMaiMai's Avatar
what the muffinman (Chuck Norris) said...if you are in cali, you're bent over and boned before you knew it.
Old Oct 11, 2009 | 08:46 AM
Shwilson's Avatar
thanx for the info thats a definately an option
Old Oct 11, 2009 | 08:55 AM
THC07's Avatar
Use the ecu that you have. it WILL work!
what state are you in?
Old Oct 11, 2009 | 08:57 AM
Is the new motor OBDII ? I'm unsure when/if the changeover from OBDI occurred in Japan.
If it's OBDII you could probably have your current ECU working with it. If it's OBDI you have the issues.
Old Oct 11, 2009 | 12:28 PM
mid 95 here in the states but I would not be suprised if it was company wide at that time
Old Oct 11, 2009 | 03:26 PM
Shwilson's Avatar
Im in PA. and i thought the ecu i have would work but i was searching around and people said they were having problems with the LEV w/ the ULEV ecu. but the motor should be here this week and ill be putting it in next weekend so ill let you guys know what happens. Thanx for the help
Old Oct 11, 2009 | 04:04 PM
Yeah that would be my guess as well, though sometimes Japan gets stuff earlier/later. Until he gets the motor I guess he'll have to sit tight.
wade9233
Jun 19, 2013 04:07 PM
dizzyroc88
Dec 21, 2006 07:54 AM
92accordh22a
Dec 5, 2006 12:02 PM
JDM.Sleeper
Jun 9, 2005 08:05 AM
AznInvasion
Nov 30, 2004 05:57 PM
