b16 or b18c5
Old Oct 9, 2009 | 10:06 PM
ej_all_dai's Avatar
Default b16 or b18c5
ok so what you guys think
i narrowed it sown to these 2 engine
a boosted b16 or a NA c5.
its going in a 99 civic
Old Oct 9, 2009 | 10:08 PM
roycivic92's Avatar
Default Re: b16 or b18c5
depends na stock c5 or built or b16 turbo stock or built
Old Oct 10, 2009 | 05:06 AM
ej_all_dai's Avatar
well if i turbo i am gonna build it
and c5 i will do head work or just leave stockl not sure yet
Old Oct 10, 2009 | 11:40 PM
NorCal_iLLesT's Avatar
boosted b16 imo.
Old Oct 10, 2009 | 11:42 PM
MHDesigns's Avatar
What about a boosted b18c1?
Old Oct 10, 2009 | 11:43 PM
Danthemagicbum's Avatar
Originally Posted by NorCal_iLLesT
boosted b16 imo.
X2
Old Oct 11, 2009 | 05:12 AM
batallic's Avatar
x2
Old Oct 11, 2009 | 05:39 AM
mr.jamrock's Avatar
too many people have a gsr go b16 or even b18a they build power fast
Old Oct 11, 2009 | 11:52 AM
MHDesigns's Avatar
who cares if others have it. A boosted gsr would make easy, and somewhat reliable power. b18a=Full build to work right and a b16 = torqueless wonder.
Old Oct 11, 2009 | 12:02 PM
boostedNOTHARDLY's Avatar
Poor mans type R?
Old Oct 11, 2009 | 12:12 PM
SergEK's Avatar
A pistons and rod turbo B16 should be 500whp capable
But beyond power will be what the intended use of the car is
If you going NA seriously youll need a 2.3-2.4+setup like a big H/F setup or Big K....baby B series blocks are a waste of time now
If your going boost the supporting mods will cost so much that the block you start off with is the easy cost....being that the B16 is a torqueless wonder it has an easier time actually putting the power down on real street tires....if you are gonna roll race then the higher toque stuff is nice but overkill on street tires
An easy fix would be to run an F20B motor with bolt ons (more power than a C5) and if thats not enough you can boost it. It has metal sleeves and an H22 head with Type S cams.....you should eclipse the power production of a stock B16 setup with the F motor and if you get crazy NA or Boost later on you can stuff a built/bored/stroked F22 block under it later and shoot for 800+whp
Or you can waste your time and money on a built C5 motor only to lose to Big H/K setups who spent about the same as you.
teknicalissue
Aug 21, 2010 01:54 PM
nboost
Mar 21, 2006 06:39 PM
blazin
Aug 27, 2002 08:13 PM
